Weak Spark on 1 Cylinder
I have an 2002 S60 AWD with a weak spark on the number 3 cylinder. I have swapped the plug, coil, injector with other cylinders, just to satisfy curiosity. I am throwing code P-0303. This miss has been occurring once in a blue moon for at least 1 1/2 years and could not find any cause. It has finally broke and I am needing a good starting point. I have been looking at the Ignition Control Unit but can not find its location on the car.
- Has thanked: 1614 times
- Been thanked: 4078 times
The coil on plug ignition works with constant 12 VDC on the coil and the ECU grounding the coil to fire it.
Once you confirm the 12V is good, and the wires are good, swapped coils and plugs, the only thing left is the grounding wire to the ECU.
- 9 Replies
- 1793 Views
Last post by Pacoddog
- 16 Replies
- 1187 Views
Last post by Kokonradus
- 651 Views
- 20 Replies
- 4920 Views
- 11 Replies
- 2256 Views
Last post by Sommerfeldt
