Need help with error codes Topic is solved
doublebug
Year and Model: XC90 2007 D5
Been thanked: 7 times
Post by doublebug »
Standard big relay and some tool to adjust contacts
If you have questions about Volvo firmware ask me. I may know an answer :)
mrHook
Year and Model: v70n 2002
Post by mrHook »
doublebug wrote:Standard big relay and some tool to adjust contacts
So basicly just a single highbeam relay should be fine I supose or similar that is 12v and can take some amprage (30-40 amp).
doublebug
Post by doublebug »
tomorrow I will do the same repair but will change the left relay.
mrHook
Post by mrHook »
doublebug wrote:tomorrow I will do the same repair but will change the left relay.
To bad you live to far away otherwise I would have let you do it aswell :), will I need to reconfigure my car afterwords with new software?
Perhaps I should replace em both in precuation. But I read some where about the OHm's and things... I'm not so good at this, I have found a standard relay at 30 amps 12 volts. But are all relays configured same way over the pins so nothin bad happens also does the apms, ogms in coil etc make any difference?
doublebug
Post by doublebug »
no need of reconfiguration just replace relays and that all.
BTW
Recently I've been in Sweden. Visited Volvo factory. But at that time you had 2002 MY :)
mrHook
Post by mrHook »
doublebug wrote:no need of reconfiguration just replace relays and that all.
BTW
Ah cool, so that means you might be the brain behind the brilliant idea of soldering the relays to the CEM.. mohaha "joke". SO you work for volvo or?
doublebug
Post by doublebug »
no. That was project for them to upgrade software they use to shoot crash tests. High speed cameras.
mrHook
Post by mrHook »
doublebug wrote:no. That was project for them to upgrade software they use to shoot crash tests. High speed cameras.
cool :) :mrgreen:
mrHook
Post by mrHook »
Can you reprogram every box module in a volvo if it is needed?
doublebug
Post by doublebug »
every? for your car yes but for CEM some special equipment is need besides DiCE.
