dow, aint good then, if need I have to go to a volvo service if it comes to that of new software in CEM. But as you stated before I should not need to but if I do I cant ask for your help I supose?doublebug wrote:every? for your car yes but for CEM some special equipment is need besides DiCE.
Need help with error codes Topic is solved
Nice job there, anything in particular I should think about when/if I do it?doublebug wrote:
Do you got the pin layout for the relay? I suspect that the relay I got for replacement might be in wrong pinout order.
Then I gotta change it for another. Wrote down the part-no that oyu had so gonna go and buy some of those later today.doublebug wrote:30 & 85 should be control pins
86 & 87 main pins.
You can check by applying 12v to 30 & 85.
- 3164 Views
Last post by 2001downunderxc70
- 797 Views
Last post by Ozark Lee
- 10 Replies
- 2750 Views
Last post by alemao4100
- 616 Views
Last post by happikoto
- 2836 Views
Last post by aswresm
