1996 850 PCV Problem - Simple Fix?
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
Heatercore hose is the wrong hose to use. You want OIL RATED hose.
85 GLH, 367 whp
00 Insight, 72 mpg
PeteB
Year and Model: 1996 Volvo 850 Wagon
Has thanked: 57 times
Been thanked: 11 times
Post by PeteB »
I just reread your post, yes I see that hose on ebay that you suggest, thanks.
Are the rest Volvo hoses that you use, or do you substitute for them also?
The other issue that we have is that we don't have a spare car for him to take
in case something goes wrong and I need a few days to figure it out. I suppose
that I should be more optimistic.
PeteB
Post by PeteB »
I've been reading, should I drill out the PTC valve?
bob850
Year and Model: 1996 850 Turbo wagon
Post by bob850 »
I have been meaning to try drilling out the PTC element hole as well, haven't got around to it. Curious as to whether just drilling out the hole as a first step will help with relieving crankcase pressure. Has anyone tried doing that, only, and what was the result?
1996 850 Turbo Wagon - 175K miles, ARD Green ECU, Koni FSD, IPD sways, Snabb intake pipe, IPD HD TCV
1999 V70 T5M - 220K miles, M56H swapped, 2004 S60T5 engine, IPD sways, H&R springs, Bilsteins, TME catback, tune
2007 V70R, 55K miles, mostly stock
PeteB
Post by PeteB »
We have cracked vacuum lines and I should probably replace them all.
Is there a good quality hose that I can just order 20 ft or so of?
I see that most of the parts are on sale at FCP now, so I should just order them
and replace the oil trap. I have to get the VIN on the car. Not sure why FCP
says that there are several oil trap boxes that will fit - which OEM one is best?
Has anyone cut one open to see what's inside if anything, are there any baffles?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Nothing:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
PeteB
Post by PeteB »
Thanks, very interesting.
Has thanked: 311 times
Been thanked: 817 times
There are two slightly different geometries on the oil trap box hose connections. You have to match up the right trap with the right little hose on the side, to be able to put it together. Otherwise, they are functionally equivalent.
PeteB
Post by PeteB »
Thanks Erik that makes sense.
If I had remembered that the PCV issue is mainly sludge (ours is also cracked hoses)
then I would have used Mobile 1 synthetic. I do believe the claims that Mobile 1
produces far less sludge and holds up better than dino oil. I think that we'll switch
on the next oil change.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Even an affordable synthetic blend such as Helix 10W-40 will be kinder to the PCV system than dino oil.
Using full synthetic gives no guarantees that it won't sludge up eventually; it just prolongs the inevitable at a higher mileage count :D
