1998 V70 AWD P0455 P0440 P0442 Fix with Photos
This topic is in the MVS Volvo Repair Database » V70 P0455, P0440, P0442 Fix with Photos
tom4342
Year and Model: 1998 v70 awd
Post by tom4342 »
Where is the shut off located?
Tom Hood
Has thanked: 1609 times
Been thanked: 4065 times
I think the components are located in the VRD documents up thread
terraczy
Year and Model: 2000 V70XC
Post by terraczy »
kahl wrote: 05 Feb 2015, 15:49 Following this guide I found a cracked "U" tube on my 2000 V 70 XC above the fuel tank directly behind the fuel filter. Replacing this pipe made P0455 go away.
Did you access this hose the way it was done in Eric's write up (through the trunk)? Or did you do it from underneath the car?
I have a 2000 v70xc and have been told that these parts of the EVAP system are menacing to get to!
2000 Volvo V70XC 157k
THeOldMan
Year and Model: V70 1998
Post by THeOldMan »
Mine is a 1998 V70 FWD base model. When I open the rear access panel that was covered by the wire harness, I see only a metal can that cannot be removed.
Both access panels opened
It just spins. Under the other panel there is a cap of some sort with three hose connectors, one of which has nothing connected to it.
Cap with three connectors, one unused.
And it smells of gas fumes around there! I have already worked through the engine area valves and lines, all good there. I can go 1000 or more miles with no codes or I can go 80 miles with p0455 showing up.
Do I have to work from underneath the car to get to the lines and rollover valve?
Paul
The number of miles between codes doesn’t tell tou much about the failure, that’s dictated by the drive cycle. You won’t get the code to set until the evap system goes into its “ ready to test” state. Driving over 60 mph and using the AC are two things which can inhibit this.
If your smell gas under the metal plates you probably have a holed evap line above the tank.
The toothed large ring is the access port for the fuel pump in the tank and the thick black lines are supply and return fuel lines
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Drop the tank. It's easy.
One of the vent hoses had been chewed through on ours.
