volvo 240 oil pressure sender unit
vcowens
- Year and Model: 1998 V70, 1991 240
hello everyone, i was finishing up installing a 5 bar pressure gauge in my 1991 240. I thought i was homefree until i broke off the small screw that connects with the green wire going to the actual gauge. Any ideas if and how i can fix this? as you know these sending units can be pricey and hard to find in the salvage yards. it looks like there is a small wire going thru the unit to the screw. is there any way i can get into the unit and repair it?
- IMG_4686.PNG (1.16 MiB) Viewed 5514 times
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
FAE 14870
Meyle 014-054-0040
Mercedes-Benz 001 542 56 17
Volvo 3417000
Volvo 3427000-1
VDO 360.081/030/033
VDO 360.081/030/111
I think you're going to need these numbers.
Echlin oil pressure switch at NAPA # ECH OP6138 ( has 1/8" NPT, would need adapter)
5 Bar oil pressure switch to fit 1985 Audi 4000S has M10-1.0 threads (would require M14-1.5 x M10-1.0 adapter).
Meyle 014-054-0040
Volvo 3417000
Volvo 3427000-1
VDO 360.081/030/033
VDO 360.081/030/111
1988 Volvo 760 Turbo Wagon
detroitbrick
- Year and Model: 1991 245
Hi, I've suffered the same fate. I was working on an alternator and ground wire replacement and snapped off a terminal of my oil pressure sending unit. Local auto parts supplier ran above numbers to no avail. Is there an egauges.com equivalent? Or another substitute? Thanks.
detroitbrick
VDO most likely was the original manufacturer. Of the two VDO products listed above 360-081-030-033C is a valid number in their catalog. Can anyone verify fit? It's a 5-bar with M14 x 1.5 threads. Thanks.
detroitbrick
OK. Talked to VDO tech support. No definite answer. The suggested I contact www.kienzle.de, their european distributor.
Before I go that route however, I want to check out a couple things with MVS about this.
I found a VDO sender 360-028. It's 80 PSI/5-bar, has M14X1.5 threads (is that the correct thread?) and has 10-180 Ohms resistance.
Does this thing tick all the boxes? The VDO numbers in the op are NLA. Thanks.
lummert
VDO Gauges 360-800 comes with the adapter fittings. From what I've noticed M14x1.5 threads are nearly the same as 1/4" NPT. Just as M10x1.0 is nearly the same as 1/8" NPT. So an adapter bushing for 1/8" NPT to 1/4" NPT may allow a new sensor with 1/8" NPT threads to fit a M14x1.5 straight thread using the stock copper sealing washer.
Using this type adapter:
www.suremarineservice.com/FIT-531.aspx
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
For an idiot-light sender, I think I used one from a 1968 Rambler 199-6cyclinder engine. They wanted too much for a "Volvo" sender, so I paid less than ten bucks for this sender.lummert wrote: 03 Oct 2017, 16:52From what I've noticed M14x1.5 threads are nearly the same as 1/4" NPT.
I don't know which thread type Volvo used, but in back of my mind, I recall Volvo did something different...like used NPT or something like that in earlier years.
I suspect there are not that many OEM vendors, so there may be standardized sizes in oil pressure sending units.
detroitbrick
The VDO website doesn't recognize "360-800". The Volvo part numbers, 3417000 & 3427000-1, can't be cross-referenced by VDO.
If the OEM part's characteristics could be established then a comparable replacement could be ordered, so VDO told me. The only 5-bar VDO sender with M14x1.5 threads they offer is 360-028. Can anyone confirm if this will work? BTW I have a '91. It seems the mounting hole in the block would be metric. Please correct me if I'm wrong.
lummert
360-028 is available from www.egauges.com and appears to be what you're looking for
- 9 Replies
- 3324 Views
Last post by warmblood58
- 16120 Views
Last post by Krons
- 794 Views
Last post by ifga16
- 1346 Views
Last post by stabworthy
- 1419 Views
Last post by Salomons Driveway
