Does this sound like a burnt valve?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
That is a great price for a head rebuild.Jazzer wrote:The machine shop did a beautiful job of cleaning the head as well as a valve job ($314), in 2 days to boot. As I clean up the block in preparation for assembly, I'm curious: I have read in this forum and others that scotch brite pads should not be used. Yet in multiple online resources the most common method of cleaning the surface is a green scotch bride pad, along with brake cleaner, wd40, oven cleaner, etc., etc. Should we not use the green pad, or are we referring to a different pad?
I would not use the scotch bright pads at all, not worth the risk. I had the pleasure of replacing an engine after 3 days of use after someone else used them. Almost impossible to get all of the particles cleaned out.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
With all the gunk on the top pistons, I wonder about the chances some piston rings are stuck in the grooves. Do the pistons move slightly back and forth?
PeteB
- Year and Model: 1996 Volvo 850 Wagon
- Has thanked: 57 times
- Been thanked: 11 times
How did this turn out, our 850 has not given a misfire code but it is running very rough
below 2000 RPM. Granted it needs new vac hoses and PCV but I'm very worried since
the symptoms are the same. Need to get a compression tester before I do all the
work lined up for it.
Is a Harbor Freight compression tester good enough?
I borrowed a compression tester from Auto Zone. I have the Harbor Freight one and don't particularly care for it as it seems to want to separate at the wrong place when trying to back it out of the spark plug threads.
101
1998 white V70 GLT 230K "Elsa"
1998 white S70 T5m 180K "Anna"
PeteB
Right I don't want one from HF if it is going to annoy me every time I use it.
I'll see if I can borrow one as you did, didn't think of that, thanks.
- 1026 Views
Last post by wizechatmgr
- 10 Replies
- 1750 Views
Last post by Clemens
- 645 Views
Last post by E Showell
- 565 Views
Last post by dosbricks
- 1296 Views
Last post by rspi
