2005 v70 NA coils and plugs
Has thanked: 1611 times
Been thanked: 4074 times
Replaced the last three original coils and plugs on my NA
Tools: torx 30 for cover screws, M6 for coil screws, small screwdriver , plug lube, plug socket 5/8 with insert, long extension
Notes
Cover screws obstructed by the cross brace. A wobble might be useful to remove cover
The m6 coil screws ground the high tension coil, so they must be clean And tight.
I used a small screw driver to open the electrical connector snap all the way. Careful if you do this .
Plugs looked ok, replaced as unknown mileage
Canadian Moose
Year and Model: 2002 V70
Post by Canadian Moose »
Are those double electrode plugs OEM Volvo? Did they do that for reliability in case one electrode fails you have a backup?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
:shock:
Something's missing.
Also -> Amazon link
Give the focus knob a twist, or run a deconvolution on it
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Canadian Moose wrote:Are those double electrode plugs OEM Volvo? Did they do that for reliability in case one electrode fails you have a backup?
NA's use DENSO pronged plugs
Canadian Moose
I am surprised that OEM would run those. I always thought that single electrode plugs were the best. Electricity goes the path of least resistance so single electrode makes sense to me.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
N/A engine has 3-electrode plugs, turbo - 1-electrode.
