at first no start.. no spark..rewired the radio interference relay connector.. change RPM sensor.. viola..!!!
but the seatbelt warning noise is killing me..
and the front brakes vibrate quite hard.. is it the ABS? or the brake itself?
finally.. it start up with no hesitation or whatever...
harryhendo
- Year and Model: 940, 855, S70, V70
Re: brakes
If you feel the vibration in the steering wheel when you are not applying the brakes, then the wheels are either unbalanced or out of line (needs an alignment)
If you feel the vibration in the car (seat of your pants) when you press the brakes, then the brake rotors are warped and need to be machined or replaced.
'92 940
'94 855 (manual!)
'00 S70 (manual, the $500 experiment)
'02 V70
'94 855 (manual!)
'02 V70
- 286 Views
Last post by kaneelschep
- 1403 Views
- 723 Views
- 22 Replies
- 8682 Views
Last post by osman
- 11 Replies
- 2650 Views
Last post by dorvin
