1999 C70. V70 Window Switch in a C70
volvooh
Year and Model: '98 S70, '05&'08 V70
Been thanked: 4 times
Post by volvooh »
I need to replace the driver side window switch in my 1999 C70. Replacements I have found for the C70 are in the hundreds- some as much as $200, while I can find a replacement switch for a V/S 70 for less than $50. My question is would the S/V switch work in the C70? The biggest difference I can see is the window lock vs. the "all in one" up and down on the C70. I can live without that feature for the savings of $150 or more.
Has thanked: 1500 times
Been thanked: 3812 times
Can you pull part numbers for both?
We should also look at the wiring diagrams to see if the connectors will work.
Changed thread title fir search
Here is the V70"switch. 3/97 is the main switch
Opinion. After looking at the functionality here I doubt this swap will work
volvooh
Post by volvooh »
That's too bad...the C70 switch is much more expensive! Would I lose the "all in one" function only or do you see the whole switch being incompatible?
obayha
Year and Model: V70 1999 Base
Post by obayha »
Is switch broken? Or in need of a good cleaning?
Can the parts from a V70 work as replacement parts in your switch?
Just wondering if the parts are interchangeable to some degree.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
The S/V's have a bare bones, switch contact based system.
The C's have a much more elaborate electronic set up
with different resistive values sent over one wire to the
window/top controller for up and down operation.
The bottom line is that the switches are completely
different under the skin and are not compatible.
It looks too complicated to just add/drop the window function , but that's just one Richards opinion
If you can find the C70 wiring diagram on the web we can compare switches and figure this out.
How about a Pick and pull from a dry state?
volvooh
Post by volvooh »
I looked on carparts.com and may be able to land one under $75.00, so that may need to be my option. To answer above, I recently had to replace the door latch and in the process of removing the plugs from the switch, the switch body came apart. When I put it back together, I had lost the central locking feature as well as the all in one window button on the bottom. I was going live with that, but then I found that I lost the rear left window functionality on the master switch as well...that one is kind of a problem. I still can put it down using the rear controller in the back of the car, but just starts getting very problematical.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Talk to one of the guys on here who get used parts. If you ask Robert (rspi) I bet he might be able to track one down for you.
