S70 headlights
rnelson1020
Replaced headlight wiring harnesses due to age and heat deterioration. Now headlights do not work. Corner amber lights work. Turn signals work. Fuses and relay look ok. All electrical connections rechecked and ok. High beams flash when I pull the left stalk on steering stalk. Any ideas?
- Year and Model: Many Volvos
- Been thanked: 76 times
The next logical place would be the headlight relay. How bad did the old harness melt? Bad enough that it shorted out?
harryhendo
- Year and Model: 940, 855, S70, V70
I would pull the wiring connector off the low beam bulb, and hook up a test light to the positive wire to see if you actually have 12v going to it. If you do, then I'd suspect the relay.
'92 940
'94 855 (manual!)
'00 S70 (manual, the $500 experiment)
'02 V70
'94 855 (manual!)
'02 V70
- Has thanked: 1613 times
- Been thanked: 4078 times
Be careful you don't cut yourself on Occam's razor......crlande wrote:Maybe both low beam bulbs are burned out.
crlande
- Year and Model: 240DL;850;S70
- Been thanked: 36 times
The razor gets duller over a lifetime, I can attest to that!.....abscate wrote:Be careful you don't cut yourself on Occam's razor......crlande wrote:Maybe both low beam bulbs are burned out.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
I'd start with a meter on the low beam fuses with the key on
and the headlight switch turned up to the 12:000 position.
Locations 21 & 22. Check the two nubs in the top of each
fuse while it's still in place. They should be hot at both ends.
If you have power getting through the fuses, check the stuff
that you touched before you start shotgunning other things.
9 times out of 10, if it worked before you got in there,
something happened where you were servicing the vehicle.
Is there voltage on pin 2 of the 4 pin headlight connectors?
Where'd the new harness's come from? New or used?
Did you confirm that all the wires line up pin for pin at the connectors?
Do they meter out pin for pin?
Do the headlights work if you put the old harness's back?
Here's a visual:
Here's a visual:
- Has thanked: 312 times
- Been thanked: 818 times
crlande wrote:The razor gets duller over a lifetime, I can attest to that!.....abscate wrote:Be careful you don't cut yourself on Occam's razor......crlande wrote:Maybe both low beam bulbs are burned out.
- 3500 Views
Last post by ShadowDancer
- 996 Views
Last post by c70_lindsay
- 1879 Views
Last post by 101
- 5331 Views
Last post by Eddystone
- 23 Replies
- 3866 Views
