After start car might have a so called limp mode on the low RPM and after computer reduce throttle (or close it completely) and I can go not more then 5 - 15 miles (rolling from hill adds the speed
I have a yellow sticker ETM.
I did VIDA ETM test differences was not more then 0.79%.
According XeModex flow chart pulled ETM fuse it looks like ETM works fine (I heard just one click in the end)
Any suggestions what do I need to check?
I pulled the following codes using VIDA for different events
The first set of VIDA codes:
ECM-903C Reconfiguration emission system - Information
ECM-904D Text message - Information
ECM-9190 Throttle position (TP) - Faulty current
ECM-91A7 Throttle position (TP) - Faulty control
ECM-91F0 Throttle position (TP) - Faulty current
ECM-903F Throttle position (TP) - Signal missing
The second set of VIDA codes
ECM-902A Communication with throttle unit - Signal too low
ECM-917F Accelerator pedal position - Faulty signal
CEM-1A5D Communication with ETM control module Signal missing
The third set of VIDA code
