pollen filter
kcv70
Year and Model: '15 XC70; '12 XC89
Post by kcv70 »
2012 XC90 FWD. I changed my cabin air filter this weekend. I'm glad I did this service myself because there were filters in both slots, which is probably not what Volvo intended. The dealer missed this and so did my independent mechanic. I removed the the thinner non-IAQS one and replaced it with the thick Mann CUK 2855 charcoal filter. Thanks to Mann's instructions I realized there are 2 slots.
Jaguar xjs
Year and Model: 1996 850 turbo
Post by Jaguar xjs »
I bought my car about a month ago. There was a musty smell, I know old cars have a certain smell but this was different. The filter must have been the original!
So I removed the filter and started the the car and allowed it to reach operating temp. I then turned the fan on high and turned on the heat. I then sprayed Lysol into the chamber a couple times cycling the knob to run the Lysol through the different vents. I then turned on the AC and sprayed away again. I did this for about an hour, cycling back and forth between AC and heat and position.
Installed a new filter and once the Lysol smell wore off in about and hour, the car smelled nice and fresh with just a hint of old car smell.
Gordon
1996 850 turbo
1994 Jaguar XJS 4.0
1976 Triumph TR6
2012 Scion Xb
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Replace at 15K miles...older 850's didn't have them...one of the main causes of the A/C evaporator crapping out.
benpineapple
Year and Model: '06 V50 T5, '13 XC90
Has thanked: 5 times
Been thanked: 4 times
Post by benpineapple »
I change mine every fall after the leaves go. I sit in the car with climate control the most in the winter, so it makes sense to me. Plus I put 25,000 miles on my car every year. The $15 on a decent is worth the fresh air. I can definitely tell when it's starting to go.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
btw., does anyone know if the pollen filter assembly out of the 98 up V70 fits the 850? I think so.
1996 855 R,
2010 V70 D5,
Has thanked: 2210 times
Been thanked: 1852 times
Yes it does. I did it on the 97 850 overhaul/project.
All you need to do is to pull the old plastic unit out of the 850 and fit one from a 98-00 S/V 70 with the filter.
I took the opportunity to pull the wiper arms and the cover off from under the windshield area and clean all the accumulated crap out from there and clean out the 4 drain tubes (2 in the air inlet are under the plastic cover and 2 from the plastic cover) and the area around the cold air intake flap. Also took the opportunity to clean and grease the wiper motor and assembly so it ran smoother.
Clemens
Post by Clemens »
Thanks, Neil!
1996 855 R,
2010 V70 D5,
Clemens
Post by Clemens »
Btw, I just talked to my Volvo parts guy (he's owned 10 850ies over the years) and said never to use the active charcoal filter because especially on the 850 the blower motor wasn't strong enough and eventually got hot enough to catch fire. Volvo stopped selling them (at least in europe) for that reason.
1996 855 R,
2010 V70 D5,
Has thanked: 1611 times
Been thanked: 4075 times
That sounds like MUSE...made up stuff excrement.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
I do them about once a year, usually in the Spring, that works out to about 15,000-20,000 miles for me.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
