I am curious if I can get a decent cleaning of the throttle body without removing it totally?
This way I can notice if the problem persist and comes back.
I have been reading that without removal of the manifold the TB can be a pain in removal.
I haven't come across anyone that mentioned a cleaning without removal.
thanks
PS when do you suggest that a TB replacement in necessary? Other than a mechanical piece that may be broken or worn out?
Can I clean a Throttle Body properly without total removal?
- F250
- Year and Model: 2007 S60 2.5T
I can't speak to a regular cleaning schedule, but I recently did the one on my daughter's 2.5T when I did the PCV system replacement. The intake manifold had to come off for that job anyway, so I just added the TB cleaning to the job while I was already "in there."
Having therefore done the job myself, I cannot imagine even trying to clean the TB without removing it from the manifold, and that is more easily accomplished by first removing the manifold for the cleaning job. Otherwise, you are not going to be able to clean both sides of the flapper in the TB, and both sides should be cleaned. Before you do this, make sure that you have a good 10mm crows foot wrench to get that last manifold bolt by the power steering pump, and know that it does not have to come completely out of the block... just loosen it... there is a slot in the manifold to accommodate slipping it off that bolt while the bolt is still in the block.
______________________________
Pete - '07 S60 2.5T, Gray FWD (Daughter's car)
My Garage includes '02 F250 7.3L Diesel w/285K, '03 Excursion 7.3L Diesel w/196K, '06 Outback Limited 2.5L w/228K, '99 4Runner 3.4L 2WD w/220K
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
On a non turbo it's easy to clean it in place in and out, on turbo models I think it's placed differently and not accessible
- F250
Well, then, if you're replacing the PCV, it all has to come apart anyway.
JRL
- Year and Model: Several
- Been thanked: 16 times
We always clean the TB during a breather job, much easier, also replace the spark plugs at this time
It will run like a new engine when all done.
Yes, non turbos are easy, it's staring right at you, but not with a turbo car, removal is the best option
I just cleaned mine when doing the PCV system, and with how baked on the residue was, and how much scrubbing/spraying/scrubbing/spraying there was to get it clean, I can not imagine doing it in the car and doing a good job.
- F250
That was exactly my thoughts as well, fixer333. Even if the TB position on a non-turbo engine is right at the air filter housing , I would still not want to be bent over scrubbing for as long as mine took. Having it off the engine where I can sit at a work table/bench was much more to my liking!
- 794 Views
Last post by Olegs855R
- 1425 Views
Last post by 454cid
- 1668 Views
Last post by loshax
- 514 Views
Last post by volvolugnut
- 844 Views
Last post by jimmy57
