Water in footwell
qwertyjjj
Year and Model: V70 2004
Post by qwertyjjj »
After a lot of rain, there was about 3 inches of water in the driver footwell today.
Can this be caused by a blockage? There's 2 areas where leaves and pine needles gather between the bonnet and front window under the wipers. Is that a drainage area?
JDS60R
Been thanked: 3 times
Post by JDS60R »
Assuming you have a moon roof.
Open it and clean all 4 drains carefully
Retired
qwertyjjj
Post by qwertyjjj »
JDS60R wrote:Assuming you have a moon roof.
I can see 2 drains between the bonnet and windshield.
These were also blocked.
Could that have been the cause? I would have expected excess water there to just flow off the side of the car.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Another one is under right side support of rear bench.
qwertyjjj
Post by qwertyjjj »
The back seat? :?:
Actually under the seat or in the door...
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
The sunroof drains can be blocked, but I don't see how you'd get 3" of water with the sunroof closed. Or was the sunroof left lifted?
Look at the door rubber seals, all around, it was a somehow common issue. Twist the seals looking for cracks in between the rubber. Also check the horizontal seal outside at the bottom of the door glass along with the drain holes at the bottom of the door. I'd check as well closely around the windshield sealing.
The grid at the bottom of the windshield is not supposed to let water past the firewall.
qwertyjjj
Post by qwertyjjj »
oragex wrote:The sunroof drains can be blocked, but I don't see how you'd get 3" of water with the sunroof closed. Or was the sunroof left lifted?
I'll try those. What I meant is that the grid was blocked with leaves causing water to build up on top of the windshield seal. I could see water dripping from below the steering wheel... just above the plastic above the pedals
vtl
Post by vtl »
You need to reseal your windshield then.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Both areas can be bad
All 4 sunroof drains and the cowl/windshield area and lower windshield molding
oragex
Post by oragex »
Interestingly, while installing today an amplifier under the passenger seat, I noticed the foam under the passenger carpet was soaked. I haven't yet checked the drivers side. The carpet itself is dry, but the white foam underneath is soaked.
I don't know yet what the exact issue is, I'll will check first the drains under the dash - as explained here
There is also this video talking about the roof drains
