That's what i thought you did....the problem is in soldering.You have higher resistance than it's supposed to be and that's why ecu reports error code for it.
Same case when people used to solder connectors for o2 sensors.
Crimping is better solution.Return everything like it should be and it ect code will disappear...if the rest of the wiring is ok.
850R: Hard warm starts,fan issues, Coolant temp Sensor & more!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
I disagree - A good solder joint should make virtually no difference in resistance.misha wrote:That's what i thought you did....the problem is in soldering.You have higher resistance than it's supposed to be and that's why ecu reports error code for it.
- misha
I agree with you on this for most connections.....but ecu is pretty sensitive about resistance differences...and ECT sensor is NOT the one you want to solder wires to.
Every connection have some loss but soldered connection loss is minimal.That minimal is not good enough for ecu.
That said.....if soldering is not performed well,solder joint will have more resistance than acceptable and it would act like there is no solder at all.
I don't get it why crimping is better method than soldering....but for sensors...in practice....crimping shows better results.I also always thought that soldering is the best solution....but again....other's experience show different.
Bosch made crimping set and a box for their O2 sensors because of problems after soldering wires.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- BEJinFbk
But the coolant temp sensor is just a thermistor.
And when these systems get engineered for use
in the field, like an automotive application, they
generally run a pretty wide range of impedance for
a designed temp range just to rule out problems
like sketchy connections.
A bad solder joint would have to be really,
really bad to significantly increase resistance .
I honestly think that a good solder joint with
high quality, hot melt shrink tubing for water-
proofing should be as good or even better than
the OEM weather-pack connector.
You just can't unplug it...
Agree to disagree, I guess.
- misha
I wonder what could go wrong that brand new Volvo ect is throwing codes and not working as it should?
What could happen is WRONG ect or solder joints.
Can you give us part number of that ect you bought?
Could be that problem is somewhere in the wiring harness.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- BEJinFbk
I wonder if there's a problem at the ECU connector?
Maybe remove the ECU, inspect the connector and reseat it?
bewinder
- Year and Model: 1997 Volvo 850-R
Crimped the words going to the ect. No changes. Still getting hardcstarts, fan issues, throttle response issues, flashing arrows. I'm hesitant to continue treating them as isolated problems, especially since they alll started within a few day span...
- misha
Time to check some wiring and relays or a visit to a good car electrician.
Iac valve MUST NOT buzzz when engine is off.Something is shorted out.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 2500 Views
Last post by prwood
- 3029 Views
Last post by bmdubya1198
- 757 Views
Last post by oragex
- 1316 Views
Last post by richardgengle
- 11 Replies
- 8927 Views
Last post by oragex
