No overdrive after engine swap?
olddaddy
- Year and Model: 15-V60/00-V40
So we swapped in a low miles engine into our 2000 V40 after an overheat killed the original. The car runs great, better than before, but does not shift into overdrive. At 70 mph it's turning 3K rpm, well above normal. Any idea what may have happened? Did we bump something, forget to attach something, upset the shifting gods?
Life is Outstanding!
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
Dumb question, but is it the same gearbox?
No CEL?
No Upshift Light?
No CEL?
No Upshift Light?
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- alschnertz
Is it the right fluid and up to "full" when hot? I believe the 4sp (AW 50-42) uses Dexron III/ Mercon.
Maybe row the PNP switch back and forth 20 times?
Unplug / replug the connectors?
I realize this is basic, but I've got nothing else.
Good luck.
Good luck.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
olddaddy
I appreciate the reply, and though basic, on the mark. Fluid is correct and clean and full, PNP switch is new and properly adjusted......connectors may need unplug/replug activity over the weekend.
- 236 Views
Last post by volvolugnut
- 15 Replies
- 5262 Views
Last post by soulvoid21
- 439 Views
Last post by perhss70
- 18 Replies
- 2936 Views
Last post by WhatAmIDoing
- 1489 Views
Last post by 93Regina
