Water in footwell
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Sunroof drain clogged, A/C blower drain hose may come off, cracked windshield seal, or, hey, your car is at age for a leaking heater core!
Didn't you have unexplainable headaches recently? Ethylene glycol is poisonous. Was it a water or something greasy?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I went to have a look and here's what I've found. Side note, all my drains seem to be clear and work properly.
vtl
Yes. Second row right side, pull side support, you'll find another drain hose there.qwertyjjj wrote:Hmm. Now it's wet on the back footwell only. Is there a drain that goes to the back doors?
qwertyjjj
- Year and Model: V70 2004
And on the left? It's the left footwell that's wet.vtl wrote:Yes. Second row right side, pull side support, you'll find another drain hose there.qwertyjjj wrote:Hmm. Now it's wet on the back footwell only. Is there a drain that goes to the back doors?
Where does this one drain out to? Ie if I pour water on the roof, I should see 2 drips at the front under bonnet and 2 drips for the back somewhere else?
- oragex
On the left, there is a 10" long hose going from the left side bottom of the climate unit into the firewall right behind the gas pedal. A big warning, do not disconnect this hose from the firewall, it took me 15min to put it back on. Just unplug it from the climate unit, and blow through. Side note, usually the left footwell gets wet from the sunroof drain in the A pillar.
The front carpets can be removed from the car - to let them dry - by removing the two front 14mm bolts from the seat rails.
qwertyjjj
Front 2 corner sunroof drains are fine. Although front left runs slower. By the way I took off the plastic but i can't get to the tube anyway, it's behind metal... You can see it in the top left here before it goes behind the metal frame.
How do I test the back ones? Wherever I pour water into the sunroof drain just all goes forwards. I also cannot see the rear corner drain holes as the glass is in the way
- oragex
Mines too pass through the A pillar, not accessible. I'd just plug a tube where the drains holes are on the sunroof frame, and blow or pour water
qwertyjjj
Speaking of which isn't there any chemical I can put down to unblock it? Like drainooragex wrote:Mines too pass through the A pillar, not accessible. I'd just plug a tube where the drains holes are on the sunroof frame, and blow or pour water
I could try blowing down it but the hole seems rectangular in the roof drain. Attaching a tube might not make a good seal.
- 1008 Views
Last post by RickHaleParker
- 9 Replies
- 5196 Views
- 1069 Views
Last post by SuperHerman
- 9 Replies
- 3556 Views
Last post by volvolugnut
- 915 Views
Last post by bigbrain
