Son called me last night about my old 99 S70. He said the headlight switch has to be held in for the headlights to work. He is driving with his left foot on the switch right on the gas.
Bad headlight switch? Or am I missing something? To change just pop it out and undo plugs?
Thank you in advance for your help.
99 S70 T5 Headlight switch has to be held in to work
- Been thanked: 4068 times
Check that the recall wAs done in case you can get it for free from Volvo
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Definitely a bad headlight switch. Pop it out, unplug, plug in new one, re-insert in dash and you're good to go. Takes all of five minutes. Be careful with the removal. Get a Swiss Army knife or other thin blade in there and pry. As noted in a post below, the plastic tends to be brittle so be extra careful/gentle. This is not a "get a bigger hammer situation."
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Been thanked: 504 times
This HL recall was supposed to happen some 18 years ago LOL.
Check to see if you can get a free HL switch from Volvo.
I buy an extra switch (used) from ebay and throw it in the glove box as spare since this is a critical item (cannot drive w/o HL at night!).
In my car the tabs that hold the switch together broke so the inside part is not held in tight enough against the housing. Probably the same issue you're facing. That volvo plastic gets really brittle after 15 years.
blandis
- Year and Model: 99 S70 T5
- Been thanked: 3 times
Appreciate the feedback. I pulled the dash to repair the broken mounts last summer. I will have him pull it out and make sure it is plugged in properly before replacing. Will also call volvo about a free switch if it has not been replaced.
Appreciate the responses.
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
I bought a 1998 V70 new back in 1998, the HL switch went out in 1999, exactly one year later.
The HL switch was made in Ireland with very flimpsy plastic.
It was a free recall. The 2nd switch broke a year later (in 2000).
So I got tired of it and "took the matter in my own hand". Here is what I did, and it is free.
All you need is:
- Old telephone wire (the landline telephone wire with solid copper). Just take one wire from the bundle.
- Electric Drill.
Removing the HL switch is 1 min deal, very very easy.
I took this pic from the web to show you what I did:
- The tabs are very flimsy, they break with time (Green arrows show broken tabs)
- The back of the switch will come apart (Blue arrow)
- The fix is very very simple, drill a tiny hole using bit less than 1/16" in size.
Make sure you drill only 1mm deep!!! Anything deeper: you risk damaging the internal anatomy.
- Then use the thin telephone wire (use insulated wire so it does not cause shorts inside) and pass it through like this:
Hole #1 ---> inside switch ---> hole #2 (on the other side) ---> around the Back side of the HL switch and gently twist-tie it (2 turns is enough, anything more than that will break the telephone wire).
HTH.
All you need is:
- Electric Drill.
HTH.
- 25 Replies
- 4397 Views
Last post by vtl
- 2927 Views
Last post by misha
- 1083 Views
Last post by Georgeandkira
- 15 Replies
- 1647 Views
Last post by VPrints
- 752 Views
Last post by rspi
