air intake sensor 98 s70 t5
mattfromtn
- Year and Model: 1998
Getting a code for a intake air temp sensor and I'm not sure where the sensor is located, is that the same as the two sensors on the bumper cover or something different? I search for the part of fcp euro and it says its for 99 up
LUDErunner11
- Year and Model: 98 S70 T5
I believe the intake air temperature sensor is integrated into the MAF sensor. Please, someone else chime in if I am wrong.
- Stu70
- Year and Model: 2006 Sonic VR GT
- Has thanked: 34 times
- Been thanked: 26 times
Sensor is located where a MAF would be on a P2 car. Find the air box, big round tube coming out the left side - sensor is two wire (usually blue coloured plug) right on the top of that. An inch or so from air box lid. Will bring up a 1-2-2 flash code. Usually fairly robust component. Remove from rubber grommet,clean and check resistance - about 2.2k ohms at 20 degrees C.
Check plug for corrosion/ bad contacts and the wiring at edge of air box - can rub through with vibration.
Hope that helps
Stu
!!sorry overlooked the T5 bit - this would be for N/A
^^ +1 Its in the MAF sensor
Hope that helps
Stu
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
mattfromtn
Sorry to bring this back up but I replaced the maf with a known working one from my other 98 t5 and it still throws the code. Any suggestions?
- Has thanked: 312 times
- Been thanked: 818 times
What code is it throwing?
- Has thanked: 1611 times
- Been thanked: 4075 times
A lot of code readers don't map the P code to the correct symptom. You probably don't have bad air temp sensor.
Post the P code so we can confirm that. IF someone reads it for you, don't let them give you the fault, get the P code.
mattfromtn
Been pulling it myself with Bluetooth obd2 and the app on my phone it's p0112.
This p0112 code causes a lot of confusion. I think this is what is going on. It is true that on a 98 the MAF calculates intake air temps, but that function has nothing to do with the p0112. I am pretty sure that on m4.4 cars, the p0112 traces to the temp sensor "with the blue connector." On a 98 it is usually on the passenger side of the car, up front near the little grill in the bumper:
By the way, this is the exact same sensor part that is plugged into the gray connector over on the driver's side, for the ambient air temperature (AAT) display on the dash. So there are two of these on the car, but p0112 relates to the blue-connector one. I don't know if this IAT actually figures into engine management; is the fuel economy bad now that you have this code?
Here is a shot of both sensors on a 97 850, but they will be on separate sides of the car on a 98: Course of action for me would be to examine/clean/unplug/replug the sensor on the blue connector. If that doesn't fix it then likely the sensor itself is bad. The sensor is the same part as the ambient temp one (gray connector), so just swap them around to test (assuming your in-dash temp display is working OK?). The dash display will go to -40 if the sensor is disconnected or bad, and the p0112 code should go away if the other sensor and all the wiring is good.
Please let us know what you find!
mattfromtn
I will check out thanks a bunch!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I don't have that blue sensor on my M 4.4...at least not at that position.erikv11 wrote: Here is a shot of both sensors on a 97 850, but they will be on separate sides of the car on a 98:
There are two holes on the carrier,but only one sensor is attached there.The grey one.
Is that only for turbo models?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1590 Views
Last post by 454cid
- 1391 Views
Last post by mar601
- 39 Replies
- 8911 Views
Last post by precopster
- 1324 Views
Last post by oragex
- 568 Views
Last post by oragex
