my 1998s70 heater won't turn off even when car is shut off. drains the battery as a result.
chunk2sandy
- Year and Model: 1998 s70
When I turn my car off the blower for the heat continues to run draining the battery. Help!
- Has thanked: 311 times
- Been thanked: 817 times
It's the "blower motor resistor" if the car has MCC, or if the car has ECC it is the "power stage." It will need to be replaced, junk yard is the way to go.
Until you can fix it, pull the fuse to the heater blower motor.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
The manual and electronic climate controls work in different ways.
It's pretty important that we know which system your car has.
If you have an AUTO position, a variable fan control and degree
numbers on your two temperature controls, it's electronic (ECC).
If you have no AUTO, a 4 speed fan switch and no temp numbers
on the two hot/cold dials, it's manual (MCC).
Whatcha got? I have a funny feeling it's a MCC and the fan speed
switch is cooked. And the fuse is #31 for both types.
- 15334 Views
Last post by FREEBUSINESSES
- 2679 Views
Last post by cleven
- 17 Replies
- 2710 Views
- 13 Replies
- 3312 Views
Last post by oragex
- 193 Views
