horn, cruise, sunroof stopped working
dhill1725
Year and Model: s60 2001
Post by dhill1725 »
Horn cruise, sunroof stopped working. sometimes we get in the car and car will not even crank. Later on that day it will just start. All fuses are good.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Year, model and mileage surely would help here!
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
as above, what mileage? seeing a 2001 in your signature may imply 130k+ mileage. check in the first place the pulleys on the serpentine belt - alternator, tensioner and a/c compressor ones. Then measure the alternator is charging properly and inspect the power cable nearby. Alternator not charging well will cause the battery to wear. If all checks fine, I would suspect the battery got weak.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Fix alarm siren, they all develop a leak in battery, which dissolves circuit board underneath. Or at least have it removed from the car. Don't buy a used siren, they all leak. Either buy a new one or fix yours. That will fix your sunroof, which sits on the same computer bus as alarm siren does. Also the car is trying to charge malfunctioning siren battery, which can drain the main battery just over one night.
No crank on earlier models is often a bad starter solenoid contact. There's a small wire attached to starer, remove it, clean all contacting surfaces with contact cleaner, make sure car is able to start (i.e. the contact is reliable), then put some dielectric grease inside socket to prevent further oxidation.
Worn voltage regulator brushes on alternator is also a suspect, given the age of the car.
