2002 S60 2.4 LPT
I suddenly have had an issue with rough idle. I have the following codes:
P0132 O2 Sensor Circuit High Voltage Bank 1 Sensor 1
P0171 System Too Lean Bank 1
P2096 Post Catalyst Fuel Trim System Too Lean Bank 1
I also have P0300 through P0305 misfires detected.
I have visually checked for bad vacuum lines, not that I might have missed something, and have cleaned the MAF sensor. Any ideas out there are greatly appreciated.
2002 S60 2.;4T Rough Idle and Multiple Codes, (bad hose) Topic is solved
zanzabar
- Year and Model: '07 V70, '84 245
- Been thanked: 4 times
Probably that O2 sensor has gone bad, or needs to be cleaned, or the wiring to it is frayed, or the wiring connector needs to be cleaned?
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
look at the base of the injectors for fuel stains, they can develop air leaks,
tell tale sign is the dirt around the seals where they plug into the intake manifold.
zanzabar
Keep looking for a vacuum hose gone bad, this brake issue points to problem with brake booster hose perhaps?
VW TDI refugee
1994 855 (sold)
1994 855 (sold)
