I'm trying to take off my front bumper (2005 S60) and the step after removing the trim pieces is always to remove a 10mm bolt. But I don't see a bolt. Right? It should be right there? Same on both sides.
Thought maybe it was (somehow for some reason) behind the plastic piece next to it, but nope.
Just want to ask the pros if I'm missing something (painfully, embarrassingly) obvious, or if I've been driving around with my bumper taped on.
Oh and also. The little plastic pieces under the hood that pop out to remove bumper ... do they break easily? Should I buy replacements before removing my bumper, just in case? I have a bone tool and am not a savage.
There should be a bolt there, right?
Volvo S80
- Year and Model: 1999
- Has thanked: 7 times
- Been thanked: 2 times
Hi Janey,
I did remove my bumper on my S80 as there was creating some moisture inside my headlights and I took them out open them cleaned them and sealed.
I guess it should be the same on S60 too.
1.Open the hood and remove the plastic clips in front off the grille take a small torx ass it is flat and put some masking tape on it and don`t push too hard on them,then pull them straight out (P.S you should be just fine if you don`t rush),
2.Take the radiator under cover out it has two screws, one in each side just behind the fog lights and two clips that go on bumper, you should push them a bit with a flat screwdriver and pull it away.
3.Remove headlight wipers (8mm) bolt if you have and tubes for headlight washers and side marker light.
4.Remove bumper trim (P.S you could use small shoe spoon so you won`t damage the trim finish) starting from the upper parts near grille just under headlight.
5.Remove four 10 mm screws two near side blinkers and two in front near grille( P.s yes you should have another bolt as you supposed).
6. Remove two plastic trim under the licence plate in the sides of lower grille and under them another two 10 mm screws.
7.If you have fog lights disconnect them and then if you want remove them( three phillips screws on each one) so you don`t brake them if accidentally the bumper fall while you take it off.
8.Take out the pop rivets (could be screws) in the wheel arch plastic just them that are in the bumper height.
9.Put the side mark connectors and cables inside the fender so you don`t snap them while you take the bumper off.
10.If you have fog lights than you should disconnect a connector on driver side for fog lights for a cable that goes through bumper you can see it through side marker hole.
11.Put some masking tape in your fenders in the location where the bumper meats the fenders so you don`t scratch your paint.
12.Put your hand under bumper in sides of it pull it a little bit up and pull straight than repeat it in other side too than pull it straight out.
I hope I could help, and sorry if there are any grammar mistakes.
- 2521 Views
Last post by Kazthebassman
- 12 Replies
- 3829 Views
Last post by JimBee
- 1364 Views
Last post by vtl
- 1305 Views
- 2892 Views
Last post by dm635
