ZionXIX
Has thanked: 64 times
Been thanked: 194 times
What did you do to your Volvo today?
Post by ZionXIX »
I've mostly been a lurker on this forum for many years and have never seen a thread of this type so I decided to start one. Hopefully it can perpetuate itself. I always love reading about what every one is up to. Whether its an oil change or an engine swap, post it here.
So what is everyone up to? :D
-Z
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
I was thinking the same thing not long ago. Let's get this going!
Yesterday I clayed a bunch of overspray off from painting the driver's door and waxed my V70.
ZionXIX
Post by ZionXIX »
bmdubya1198 wrote:I was thinking the same thing not long ago. Let's get this going!
Do you get good results with the clay bar? I have never used it to be honest.
bmdubya1198
The clay bar is a great tool, but just make sure you buy a good one. I made the mistake of buying that Chinese knock-off 3M stuff on Amazon... never again! Buy a reputable brand like Mother's, Meguiar's, or Griot's. I have some thick overspray, so I'm probably going to need to go over it again, but on the lighter parts it worked great. Definitely something to try out. You'll never believe how rough your paint is until after you clay it!
Has thanked: 1504 times
Been thanked: 3817 times
Changed my oil on a beautiful 55F fall day, new Mahle filter, Mobil 1.
Got on my knees and thanked my 1999T5 for still running me around reliably at 180k miles with two last kids in college. Two more years
ZionXIX
Post by ZionXIX »
abscate wrote:Changed my oil on a beautiful 55F fall day, new Mahle filter, Mobil 1.
I bet she will give you another 100k if you keep treating her right.
clarkS70glt
Year and Model: 1998 S70 GLT
Post by clarkS70glt »
I removed the oil cooler lines with the intention of rebuilding, but after inspecting the tubing that the hoses are attached to, ended up being too rusty from upstate New York winters to rebuild, also 18 years old with 190k miles. Ordered new OEM lines, which is what I was trying to avoid. None available to score at my local pick-n-pull, they probably would have been rusty also.
ZionXIX
Post by ZionXIX »
clarkS70glt wrote:I removed the oil cooler lines with the intention of rebuilding, but after inspecting the tubing that the hoses are attached to, ended up being too rusty from upstate New York winters to rebuild, also 18 years old with 190k miles. Ordered new OEM lines, which is what I was trying to avoid. None available to score at my local pick-n-pull, they probably would have been rusty also.
You could buy some rebuilt lines from this guy.......
http://volvospeed.com/vs_forum/topic/11 ... ler-lines/
bmdubya1198
Do you know if he still sells those lines? I might need to order the basic set. I rebuilt mine with what I thought was transmission cooler hose, but turned out to be heater hose. They are sweating oil and I'd really like to replace the hose with something that will hold up much better.
Has thanked: 1846 times
Been thanked: 1710 times
I did NOTHING on the 2000 'R' this weekend other than return one of the summer rims, again, to the clowns at the tire shop that fitted the summer tires. 1 leaked at the rim bead off the bat, and 3 lost some balance weights, 2 before they were fitted (found them under the last tire in the stack when swapping them over, and another fell off before leaving the garage!!
When they 'repaired' the leak, the idiot that balanced it used a screwdriver or other sharp metal object to remove the balance weights on the rear of the recently re-finished rims. Scratched the crap out of them. Took it back and now they are trying to figure out how to fix this. The rims were powder coated using a 2 step process the refinishers have now dropped where they were done. Bugger!
Next back to look for the groaning gremlins in the front end of the car......Joy!!
