Along with selling my 850 turbo wagon, (in the cars classifieds on here, tons of new and performance parts, 1 glitch) I am needing to empty out all of my 850 parts at this time too. I have actually filled the entire back of my wagon with the extra parts and that doesn't even include the bumpers and fenders that I have. Here are pictures of everything except those just mentioned. The extra fenders and bumpers are also the dark blue color and are in excellent condition. All from 95 or 96 850 wagons.
Here is a list of the most standout parts in the bunch, all of which are good working parts taken off of running vehicles. (new in the box) Air Mass Meter, cam sensor, non-turbo injectors, rebuilt starter, A/C compressor, power steering pump, alternator, dash switches, 2 grilles, (brand new) front rotor, ok used rear rotors, rear caliper, rear hatch with slight damage, still usable, turbo and non turbo engine, trans, and abs computers, tail light assemblies, 20-valve head for a 95-97 850 2.3 turbo engine (needs valve job), stock rubber intercooler piping in usable shape, turbo exhaust manifold, stock air box, unused remanufactured oil cooler lines, electric fan/shroud, heater motor, glove box, all switches and relays, crank pulley/balancer, and lots of other little stuff. Any questions, just ask!
volvo 850 turbo/non turbo wagon parts. boxes and boxes for BEST OFFER
conceptchris
- Year and Model: 850 Turbo, '95
- v9.jpg (27.61 KiB) Viewed 2128 times
- v10.jpg (30.6 KiB) Viewed 2128 times
- v11.jpg (25.24 KiB) Viewed 2128 times
- v12.jpg (27.26 KiB) Viewed 2128 times
- v13.jpg (39.84 KiB) Viewed 2128 times
- v14.jpg (35.05 KiB) Viewed 2128 times
- v15.jpg (25.42 KiB) Viewed 2128 times
- v16.jpg (19.57 KiB) Viewed 2128 times
- v17.jpg (27.63 KiB) Viewed 2128 times
- v18.jpg (37.61 KiB) Viewed 2128 times
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Do you have the front driver side turn signal assembly? I need the electrical pig tail too. How much are you looking to get for the oil cooler lines? Besides that, you don't happen to have an R front bumper, do you?
Thanks!
Thanks!
conceptchris
I don't have the later style lights (I put them on the car that I am selling), but I do have the old yellow style. They are functionally fine, but do have a slight bit of fading and probably need a good buffing to clear them up. Would you be coming to pick them up or would I be shipping them somewhere? I live in south eastern Indiana. I would just sell the whole set of 4 if you want them to have extras. $30 if you come get them, $35 if I am shipping them to you. Sound fair? Shoot back if I am out of line with that.beigg wrote:how much for a set of upper tail light housings? Looking for the later white reverse lights style but may settle for an older set..
Thanks!
conceptchris
I will check on the turn signal assembly, I know I have a couple, but I will check on condition this evening. I am guessing the lenses I have are a little rough and faded though, but I should have an assembly. No R bumper unfortunately. The oil cooler lines I had done by a well respected local company and they are much beefier than the originals, I just ended up with a good set of stock ones as well from a parts car that I used, so the remade lines are brand new and have never been installed. I would take $50 for the pair if you get them or $55 if I am shipping.polskamafia mjl wrote:Do you have the front driver side turn signal assembly? I need the electrical pig tail too. How much are you looking to get for the oil cooler lines? Besides that, you don't happen to have an R front bumper, do you?
Thanks!
Thanks!
polskamafia mjl
Ok, you can PM about the turn signal. Thanks!
conceptchris
The head needs a valve job. It was switched out because of burning oil, but it ran great otherwise. I'd take $50 for it and possibly meet you within a reasonable distance with it if that helps. Thanks. PM me to continue!ems_kws wrote:How much for the head?
polskamafia mjl
Any update on that turn signal?
