You must be a Napa insidercn90 wrote:NAPA Synthetic (made by Valvoline).
Winter : 5W30
Summer: 15W50 (to reduce oil consumption)
What Brand of oil does everyone use on their P80 Volvo.
- RigsPGT
- Year and Model: Red 99 S70 T5,
- Been thanked: 2 times
99 S70 T5, The Red Devil
Ported 19T and R manifold, 3" DP with Magnaflow race cat, 2.5" cat back, Precision FMIC, Rigs intake pipe, H&Rs, Bilsteins, 302's with Akebonos, Jewels, HIDs, egg crate grille, transmission cooler.
s10lowrider1994
- Year and Model: 2000 v70
- Been thanked: 3 times
I use Rotella t6 5w40, 300k miles and counting.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
I used Pennzoil platinum, got black pretty quickly. Put Castrol Edge 0W30, got black.
Put Castrol Edge 0W40 got darker but still clear: being an average consumer, it makes me think it's better
But in any case, the 40 number is better for engines that see more action
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
M1 10w-30HM. HTHS = 3.5 cS; A good, thick 30 that works well in older, turbo motors. Replaced every 8kmi with a filter change at 4k.
M1 10W-30 HM
M1 10W-30 HM
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
Nope. I change it every 3000 miles, none of those three see more than 10k/year.theWIFES_S70 wrote:Matty Moo, you notice any difference since you made the switch to SuperTech? Those six/seven dollars... Almost a decent six-pack if you ask me. I'm due for an oil change towards the end of the month, maybe I should give it a try.Matty Moo wrote:I've been using the 10/30 super tech for a few years in all three. I also use the same 10/30 in my 22hp and 15hp pressure washers. Those get run hard and I haven't had any burning or other issues with it.
I run that same stuff in my equipment, it gets run hard sometimes up to 10 hours/day. No issues, I just change it according to schedule.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
10W-40 Mobile 1 HM, Use to change every 8k, now every 10k. Burn about 1 quart every 2,000 miles due to bad valve stem seals.
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
I always use Castrol 0w40.
850 T5-R '95 auto
- Has thanked: 316 times
- Been thanked: 531 times
I'm currently running Penzoil Platinum HM 10w30 Full Synth. It's been good, not much lifter noise or anything out of the ordinary. Before this I was running Valvoline 10w30 Synth. Again, about average. No matter what, if the car has been sitting for a day I will get lifter noise on a cold start. I haven't noticed very much consumption with either oil.
- 13 Replies
- 5515 Views
- 1871 Views
- 21 Replies
- 6602 Views
Last post by MoVolvos
- 1801 Views
Last post by bmdubya1198
- 24 Replies
- 3517 Views
Last post by CIK7
