Got an issue with the alarm on my 2002 V70. Last night I got woken up to the siren. Went outside to check only to discover my car alarm going off for no reason. I turned it off and went back to bed. Tonight same thing happened after work. Alarm went off for no reason.
Any idea what could be causing this or how to diagnose it? I have VIDA DICE unit. Would alarm store any codes?
Alternatively, can I disable the alarm completely? I am not really worried about 600 dollar car getting stolen.
Alarm keeps activating for no reason
Canadian Moose
- Year and Model: 2002 V70
Canadian Moose
They key fob?
zanzabar
- Year and Model: '07 V70, '84 245
- Been thanked: 4 times
Tailgate wiring perhaps? Do the lights stay on inside the car after the doors are shut?
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
Canadian Moose
The lights go out.
In my 2001 v70 and 2004 xc90, had same thing happen in both. Small battery in alarm module leaks (slowly) and triggers alarm. Had module replaced in 2001 for $200+. On the 2004, I was close to 200,000 miles so I took the fuse out and started leaving the keys in the ignition, hoping someone would steal it.
On the 04, you will retain the message " Alarm service required."chisholm wrote:In my 2001 V70 and 2004 XC90, had same thing happen in both. Small battery in alarm module leaks (slowly) and triggers alarm. Had module replaced in 2001 for $200+. On the 2004, I was close to 200,000 miles so I took the fuse out and started leaving the keys in the ignition, hoping someone would steal it.
Canadian Moose
Whereabouts is the alarm module located? Can the battery be replaced or do you have to replace the whole module? If I were to pull the fuse, does that just disable the siren or the whole alarm system?chisholm wrote:In my 2001 V70 and 2004 XC90, had same thing happen in both. Small battery in alarm module leaks (slowly) and triggers alarm. Had module replaced in 2001 for $200+. On the 2004, I was close to 200,000 miles so I took the fuse out and started leaving the keys in the ignition, hoping someone would steal it.
IdahoBob
- Year and Model: XC70 02, 04 & 08
agree with just pull the fuse for the alarm. You'll still have the blinky light on the dash, just no alarm. problem solved. If someone steals your old volvo, well....that's why you have insurance.
Happy Motoring!
Happy Motoring!
Idaho Bob
67, 71, 85, 98 wagons (sold)
78 coupe (gave to mechanic, thanks!)
02, 04 (X2) & 08 XC70's
before that: 67 Sunbeam, several pre-68 VW's, '41 Buick, '42 Ford Jeep, and some boring stuff
Canadian Moose
I ended up pulling the fuse. I might end up replacing the alarm or battery next summer but for now this'll do. Just curious, is it normal for the car to lock the doors by itself after a few minutes?
- 2534 Views
Last post by contented
- 6125 Views
Last post by 02V70
- 10 Replies
- 16462 Views
Last post by precopster
- 1182 Views
Last post by Mike Langlois
- 1118 Views
