Total Quartz 7000 10w-40 semi-synth,all year round in both of my cars.
Replacement interval from 8-10k km or 1 year along with Mann,Knecht(Mahle)or Bosch oil filter and copper washer (or crush washer)for oil sump plug.
What Brand of oil does everyone use on their P80 Volvo.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- smoggyama
- Year and Model: 1996 850 turbo
- Been thanked: 3 times
Any synthetic 10w min. I change oil when it looses its clarity. I keep it filled not overfilled.
Life is like a box of chocol- make that an engine compartment. You never know where the tubes go or how to rout a belt 'less you read the diagram on the underside of the hood. Do it right the 2nd time. So when all else fails, READ THE INSTRUCTIONS.
Be good do good feel good live good.
- AKJeeper
- Year and Model: 1996 850 Turbo Wagon
- Has thanked: 7 times
Pennzoil Platinum Euro Full Synthetic 5w40 on my daughter's 2000 V70 XC in the winter (car is in northern MN and sees negative temps).
Mobil 1 10w30 High Mileage in my '96 850 Turbo. Also in the '00 V70 XC in the summer.
The main things I look for in a motor oil for my vehicles: Synthetic, ACEA A3 spec (high temp/high shear ratings greater than 3.5), and approved viscosity for the engine and expected temperature range. Rotella T6 5w40 is something I've used in the past also, but in the case of the daughter's V70XC, I wanted to give Pennzoil Platinum Euro a try.
- smoggyama
Any brand of full synthetic 10-30 that's sale priced.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
My 1996 850GLT sedan I used "Mobil 1" 5W30 with Bosch/K&N oil filter and I got 300K out of her before we sold her. Our 2000 V70XC/SE I've been using "Valvoline-Maxlife" 5W30 and "Cam2 Super Pro Max" Synthetic blend 5W30/10W40 during the summer. I'm going to switch over to "Liqui Moly Leichtlauf High Tech" 5W40 w/Mann or Mayle oil filter. On our 2004 XC70 we've been using "Liqui Moly Leichtlauf High Tech" 5W40 w/Mann or Mayle oil filters. Were really impressed with LM products in general and there oil is top notch. If I couldn't get the LM I'd use Mobil 1 or Castrtol Syntec(I use this in my '99 Prelude), the Castrol Syntec is really good oil and it's available in European spec.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
combatkarl
- Year and Model: 1997 850 GLT
cn90 mentioned the Napa Full Synthetic - which is what I use. On sale for $2.99/quart through Dec. 31, 2016.
Karl
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
1984 Honda Nighthawk S bike
1997 Volvo 850 GLT
2001 Honda Odyssey
1999 Mazda Miata
2012 Dodge Journey
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Switched to Penzzoil 5w40 -- more here https://www.matthewsvolvosite.com/forums ... =switching
- Has thanked: 316 times
- Been thanked: 531 times
I'm going to get some of that while it's on sale this time around. I only got a top-off quart last time. Being that it's Valvoline oil, I'm fine with using it in my car. And for $2.99/quart, I can't complain.combatkarl wrote:cn90 mentioned the Napa Full Synthetic - which is what I use. On sale for $2.99/quart through Dec. 31, 2016.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
What ever Dino oil is on sale at the ol' Canada Tire. Yes I know, that is sacrilegious for a ~20yr old car that has no value
So either Castrol GTX, Penzoil Yellow or Quaker State Green. All good oils, my fav are either Castrol or Penzoil. I always use Mahle filter. Car runs perfectly; honestly these engines are Skookum, unless you tow, or race your car, you should be fine.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
Dino oil in an 18 year old turbo car? Let us know how that goes!
- 13 Replies
- 5504 Views
- 1868 Views
- 21 Replies
- 6592 Views
Last post by MoVolvos
- 1800 Views
Last post by bmdubya1198
- 24 Replies
- 3495 Views
Last post by CIK7
