850 t Automatic locked into park (shifter OK)
- smoggyama
- Year and Model: 1996 850 turbo
- Been thanked: 3 times
To elaborate: I heard a clunk while driving. I quickly park the car. The shifter acts normal and I can feel the engine engaged as I go through the gears, but the front wheels are locked as if its in park. I lift the front two wheels and they will rotate in the forward direction but not reverse. I cleaned the PnP and no change was effected. No CEL or codes. What's my problem? I also fiddled with the ignition switch. Sometimes I hear the clicking of the relay in the center console. Anyone have experience with this?
Life is like a box of chocol- make that an engine compartment. You never know where the tubes go or how to rout a belt 'less you read the diagram on the underside of the hood. Do it right the 2nd time. So when all else fails, READ THE INSTRUCTIONS.
Be good do good feel good live good.
- smoggyama
Tryingbe, That somehow concurs with the symptoms. Any ideas about what's broken?
tryingbe
- Year and Model: None
- Been thanked: 26 times
Without taking the transmission apart, I'm not sure if anyone can tell you.
There is a shifter cable that goes from the shifter to the transmission, but it sounds like it is working fine judging from "I can feel the engine engaged as I go through the gears", so it's something inside the transmission that broke.
I have a working Volvo trans for $40 but I'm in Phoenix.
http://phoenix.craigslist.org/evl/pts/5874453489.html
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- smoggyama
Thanks anyway.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Pay Robert to make that drive for you.
- Been thanked: 504 times
Get a 2nd person to help.
- You stand on driver's side looking at PNP.
- Someone in the cabin moves the shifter lever and see if the PNP switch moves back and forth. This procedure checks the integrity of the cable itself.
The cable hardly ever goes bad btw.
Chances are your transmission went to Mississippi...
- Been thanked: 4067 times
I think I would
Get the front end up
Confirm PnP and shifter are selecting as above
Put it into neutral.
If the wheels arent freewheeling in Neutral, I would guess the differential is locked up, but it could be in the transmission too.
Very few here tackle internal transmission repairs, most would swap out for a used one.
- smoggyama
Yeah, I agree. Cracking open a transmission is not such a good idea unless you do it for a living. The wheels spin in opposite directions while in park. This might be a solenoid or wire to? I'm still looking. I'll follow up.
Ah. The wheels will spin in opposite directions due to the differential, that's normal.
What's not normal is that they move in Park..that means there is stuff broken in the transmission.
- 536 Views
Last post by cuhfs
- 7909 Views
Last post by oragex
- 2828 Views
Last post by candice_joel
- 1123 Views
Last post by lummert
- 869 Views
