1990 740 gle gas delivery problem?
Still have the ecu squealing, but after those new parts and a rsr relay and connector replace and the aux. one next to it, just used a 5 pin relay and left off 87a which is for normally closed, taped it off, which is not needed. car is not stalling anymore. would like to fix the ecu squeal but don't know how. Thanks for the help Lummert.
Odd, when I turn the heat selector all the way right, full defrost setting, the ecu squeals constantly but when it's in the other 2 or 3 positions it doesn't squeal at all and when the heater is set to off, ecu squeals, very strange.
Are the front bearings the non service type on these?, it has the axle nut that you hit to secure it, got it off with lots of effort, no cotter pin type nut. I took it apart and can see the bearings, the bearings that auto zone had, that was suppose to match, seem way off in size and form, for about 20 more bucks can get the whole unit, not from az of course. Not even sure if they're bad, they seem to be howling, wonder if they just need repacked, maybe someone over tightened them, not sure.
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
Center support bearing for 1990 740 GLE:
AZ = 109FF
Volvo 1340501 and 183265 fits models with 50.8 mm diameter driveshaft. Bearing measures 45 mm ID x 75 mm OD. 1340501 is the support. 183265 is the bearing.
AZ = 109FF
1988 Volvo 760 Turbo Wagon
- 29 Replies
- 4985 Views
Last post by 93Regina
- 2176 Views
Last post by lolafiona73
- 11 Replies
- 2022 Views
- 388 Views
Last post by cn90
- 1106 Views
