Did you know? 🤔
Removing fuel rail on "94" 850
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 20 times
Been thanked: 0
United States of America
loveMy850
Post by loveMy850 » Tue Nov 22, 2016 4:39 pm
I need to remove fuel rail to replace oring injector, to remove the line at the rail. There is a 25 torc screw and looks like a clip between cap and rail. How do you remove the line from the rail,and what tool do I use. Thank you.
skloon
Year and Model: 94 850 95 850 04 S60
Has thanked: 0
Canada
skloon
Re: Removing fuel rail on "94" 850
Post by skloon » Tue Nov 22, 2016 5:24 pm
There are two 12mm bolts attaching it to the manifold remove them and pull the rail parallel to the injectors you don't need to remove the fuel line if you want to undo the torx and pull it straight back after removing a small clip
loveMy850
Been thanked: 0
loveMy850
Post by loveMy850 » Tue Nov 22, 2016 8:57 pm
how can that be the njectors are connected to both the feul, and rail,I realy dont agree that you dont have to disconnect the fuel line.
JeffHicks
Year and Model: 1989 240 Wagon,
Has thanked: 0
Been thanked: 0
JeffHicks
Post by JeffHicks » Tue Nov 22, 2016 9:30 pm
loveMy850 wrote:I need to remove fuel rail to replace oring injector, to remove the line at the rail. There is a 25 torc screw and looks like a clip between cap and rail. How do you remove the line from the rail,and what tool do I use. Thank you.
Unless I'm mistaken, you'll need an open-end wrench to disconnect the fuel line - perhaps 16 mm? Then you disconnect the individual wires from the individual injectors, remove the T25 screws, and pull the fuel rail straight up. There will be some resistance, but that is simply the o-rings.
This is actually a very simply procedure.
Obviously you will NOT want to do this when the engine is hot.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
kahl
Year and Model: 2000V70XC
Has thanked: 0
Been thanked: 7 times
kahl
Post by kahl » Wed Nov 23, 2016 12:21 pm
To remove the fuel line from the fuel rail remove the T25 screw. Then the square bracket plate comes out. The fuel line is pulled out. "O" rings on the tip of the fuel line should be shot with WD40 hopefully preventing the "O" from tearing. Here is a picture of that square plate.
loveMy850
Been thanked: 0
loveMy850
Post by loveMy850 » Fri Nov 25, 2016 10:04 am
Ok is there also an oring that goes there?
kahl
Has thanked: 0
kahl
Post by kahl » Fri Nov 25, 2016 10:56 am
Yes there is an "O" ring on the end of the fuel line inside the rail.
loveMy850
Been thanked: 0
loveMy850
Post by loveMy850 » Fri Nov 25, 2016 1:22 pm
Ok figured as much,whats the oring called as to where I can order it,I hate starting the job,bad oring and not having one on hand!
kahl
Has thanked: 0
kahl
Post by kahl » Fri Nov 25, 2016 9:16 pm
Fuel inlet hose "O" ring is Volvo part number 968007. The Victor Reinz part number is 407700000.
Aintezbeincheesy
Year and Model: 1994 850T
Has thanked: 2 times
Been thanked: 0
Aintezbeincheesy
Post by Aintezbeincheesy » Sat Jan 06, 2018 6:38 pm
Would anyone happen to know the particular name of that little metal piece? I dropped mine into the abyss (behind the intake manifold) and have been trying to find a replacement, or alternative means of fastening to no avail.
