Alarm Question
[email protected]
Year and Model:
Post by [email protected] »
Hi Everyone
I'm new to this board but i'll try to make my questions as easy as i can so i can get some help.
I recently purchased a 2000 Volvo S80 Turbo. It has around 140K. When i start my car i get the message "alarm system needs service" that stays on for like 15 seconds and disapears. When i check my message center is says "0 messages" and my little orange triangle light isn't on.
Sometimes I don't see this message and about the only pattern i can figure out is if I don't lock my vehicle after i shut if off and then return to it later and turn it on, i don't get the message. If i lock my doors when i leave the vehicle (i've tried using the power lock button, the fob, and the key in the outside lock, doesn't matter) and return later, when i start it the message will be there. I called my dealer and he said it was probably no big deal since the message goes away. Just wondered if you guys had any thoughts on this.
Thanks
Desirea
P.S. let me know if i need to tell you more info :D
[email protected]
Year and Model:
Got the issue under control now, thanks for the help :?
rhondaarm
Year and Model:
Post by rhondaarm »
Having the same problem-how did you resolve this issue?
Rhonda A-Z
