I love my 2005 9.5/10 for the quiet ride and gas mileage.
The 1999 makes up for it with that amazing seat
Compare the wagons! P2 vs. P80
- Has thanked: 1613 times
- Been thanked: 4078 times
tryingbe
- Year and Model: None
- Been thanked: 26 times
More parts = more point of failures.beigg wrote:Why are the 01+ body styles so attractive yet high maintenance? It's like a hot super model that has a white castle diet. Looks good..... the mess, horrible mess!
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- Has thanked: 312 times
- Been thanked: 818 times
Well, luckily this is not powertrain and drivetrain. 01 transmissions aside, I don't think powertrain and drivetrain is where any increased maintenance comes from.beigg wrote:If it's aftermarket supported with flash software for 100% changes, I'd first start with dtc scanning and proceed to check voltage and amperage areas within the vehicles system. Then if needed, run the built in module tests from the software accounting it would have such features as most I am familiar with contain it.tryingbe wrote:When this happens, what are you going to do?beigg wrote:
Can't most of those "1"s be addresed with a pcm flash in the event the need for scheduled I/M is not required?
I thought the 2002+ had the ability for real time tuning/mapping?
https://www.matthewsvolvosite.com/forums ... 28#p423028
Chances are that posters issue is alternator or battery (soon to be both) if that is happening to them out of random.
As an aside: if you have ideas what is going on over there, how about help out the OP with suggestions?
erikv11 wrote:Well, luckily this is not powertrain and drivetrain. 01 transmissions aside, I don't think powertrain and drivetrain is where any increased maintenance comes from.beigg wrote:If it's aftermarket supported with flash software for 100% changes, I'd first start with dtc scanning and proceed to check voltage and amperage areas within the vehicles system. Then if needed, run the built in module tests from the software accounting it would have such features as most I am familiar with contain it.tryingbe wrote:
Looks like a few suggestions were given that matched my thoughts. Didn't feel my .02 was warranted.
ugh smh 850 Turbo fridge
- Year and Model: Lots
- Been thanked: 128 times
In 5 years time most of you will be in a P2 or move to another Euro.....the inevitability of time.
By the way once you drive a P2 as a daily driver you will not want to go back to a P80
- misha
- Has thanked: 155 times
- Been thanked: 432 times
P2 cars are pure beauty.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
After driven one prior to having an 850, I can agree to that.precopster wrote:By the way once you drive a P2 as a daily driver you will not want to go back to a P80
As the saying goes, "first one's free" .
- 11 Replies
- 2860 Views
Last post by 1337
- 839 Views
Last post by sleddriver
- 1033 Views
Last post by RickHaleParker
- 180 Views
Last post by SonicAdventure
- 4469 Views
