Starter Relay?
Scratchy2000
- Year and Model: v70 xc awd 1998
I have a Volvo 1998 V70 XC Wagon. Recently the car wouldn't start and I noticed the battery connectors were very corroded so I cleaned all the connectors. The batter itself is slightly over 12 V when running and slightly under when not. So the battery is fine. But the car still won't start up without a jump. If i drive for a few hours then usually I can get it to start for a day or two but if it's not being used for longer than that then I will have to jump it again. Infact i drove for 2 and a half hours of highway driving yesterday and had to stop at a service area. It wouldn't start on its own after that despite battery being fine. I wonder if it's the starter relay but none of the auto parts stores in my area seem to have it and when I look online I get different names for the starter relay which makes me think I might order the wrong part. Does anyone know how I can purchase the right starter relay online and/or if that might solve the problem. Thanks!
You need to be well above 12.5 Volts with the car off for this car to run. If your measurements are good, you need a new battery.The batter itself is slightly over 12 V when running and slightly under when not. So the battery is fine
12.0 Volts at rest is a dead battery.
- Has thanked: 311 times
- Been thanked: 817 times
I agree this is more like a battery problem, than a starter issue.
When you drive the car, check to see if the battery cable ends get hot, especially the positive cable. The cable connections get bad over time this is very common, so that under usage they heat up which makes the problem even worse (higher resistance). It's very common and it will ruin several batteries if left unfixed, so check it out if you are at all considering to replace the battery.
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
I recently had starting issues, ended up being the battery cable terminal (pos+ side) was bad, so i spliced on new terminals, no issues since.
Abscate is right, that's a dead battery. source: https://www.batterystuff.com/blog/how-t ... s-bad.html
The starters themselves are bulletproof on P80s, relay failure isn't very common as far as I understand.
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
I agree with the other posters that your battery is suspect. I would take the battery to a parts store and have it load tested-- it MIGHT be OK, and you may have worn brushes in your alternator resulting in low output. I would also measure alternator output at the big red wire on the back of the alternator with a load on the system-- you should see 13.7-14.1 VDC. You should also measure voltage drops on the positive, negative and B+ cables.
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Or better yet, take the whole car.
Most parts stores have the newer charging system testers that
can be used right there in the parking lot. These units look at
everything without having to disconnect anything.
- 760 Views
Last post by ggleavitt
- 1747 Views
- 4376 Views
Last post by WA-Boater
- 994 Views
Last post by ProjectS90
- 11 Replies
- 2706 Views
