Morning all. Well, during my engine swap a few weeks ago, I chose to leave the oil filter on when the motor was out, fearing I might dent the replacement filter when reinstalling the motor. Big mistake. Oil filter replacement was the last thing on my list for the whole swap job, and took about 3 hours to pull the stuck filter.
As you know, the filter on a P80 comes in a long and short size (I use short, fear of road debris), and the short size is rather difficult to get a good grip on, due to the subframe as well as the cargo mount hook thing being in the way. The filter on my V70 was so stuck, that it bent and broke the standard filter wrench I use, and began crushing the filter in the process. Went to a local auto parts store, they recommended Lyle tool # 63500 (Amazon even sells it! https://www.amazon.com/Lisle-63500-Rang ... ter-Wrench) for stubborn filters. The tool takes a 1/2" driver, and the strap is quite strong. This is what the tool did to the filter:
And because of its design, it inserts up into the area of the filter, making tool clearance a non-issue. I'll be using it for sheer convenience on all future oil changes.
Stuck P80 Oil Filter Solution
benpineapple
- Year and Model: '06 V50 T5, '13 XC90
- Has thanked: 5 times
- Been thanked: 4 times
2006 V50 T5 [190,xxxM]
2013 XC90 FWD [80,xxxM]
2001 V70 X/C AWD [sold at 120xxxM],1998 V70 AWD [RIP at 249,255M], 1990 240 [SOLD at 220xxxM]
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Glad you got it off. My oil filter also got stuck after my M56 swap. We removed that towhook and managed to get it off with a screw driver through the filter.
I've had a lot of success with this tool from Lisle: https://www.amazon.com/Lisle-63600-Oil- ... isle+63600
The spring cup is also really good for accessing the P80 filters and its a must have when doing older Subarus that have the triangle of death.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
That was one stuck filter! The mechanic who put it must have been Hulk's brother. THere is just no reason to tighten this thing like a subframe bolt, the rubber seal prevents it from rotating and breaking loose.
Not sure if it works one these cars, but for less stuck filters, someone punched a long screw driver into the filter - with the corresponding oil mess - and got it freed by twisting the screw driver handle
I actually had a similar experience when i did a engine rebuild and the engine was out of the car.
I drove a screwdriver through the filter before I got mine off.
Cold engine & and oil filter removal is the worst filter removal you will experience...
From now on I have always removed the filter then it is still hot or slightly warm
- Has thanked: 311 times
- Been thanked: 817 times
This tool is the bomb, I have used it on so many cars over the years.polskamafia mjl wrote:Glad you got it off. My oil filter also got stuck after my M56 swap. We removed that towhook and managed to get it off with a screw driver through the filter.
- Been thanked: 4071 times
beigg wrote:The PCV system must've been severly plugged leaving that much pressure to hinder the oil filter from being removed!
That or the parking brake wasn't adjusted right?
- Year and Model: Many Volvos
- Been thanked: 76 times
Glad you got it off. I wound up not having my boat all summer because I couldn't get the filter off and I tore the filter up trying. I finally punted in June and had the marina come and get it.
I finally got it back 3 weeks ago and $800.00 later it had a new oil filter installed. They had to pull the engine to get it off. Just in time to winterize it.
Oh the joys of owning a boat! Craptastic!Ozark Lee wrote:Glad you got it off. I wound up not having my boat all summer because I couldn't get the filter off and I tore the filter up trying. I finally punted in June and had the marina come and get it.
At least the dry docking of your boat saved you from the hundreds (thousands? ) of dollars in sunk fuel costs and liver pounding..
ugh smh 850 Turbo fridge
- 1161 Views
Last post by wizechatmgr
- 13 Replies
- 3653 Views
Last post by matthew1
- 3926 Views
Last post by johnljoseph
- 10 Replies
- 2681 Views
Last post by cn90
- 15 Replies
- 2999 Views
Last post by 454cid
