Good Morning All,
I have a 2004 xc90 with about 135,000 miles. My check engine light came on and I checked the codes quickly and found that the ECM DTC seems to be the culpret. I am an AVERAGE mechanic at best but I am wondering does this typically mean the entire ECM module needs to be replaced or is this normally something else. I am guessing the answer is that it could be anything and I should have a proper mechanic look at it. I am just trying to get more information before I go in. Any suggestions/thoughts are appreciated.
Thanks!
Joe
2004 XC90 - ECM DTC SET
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
ECM DTC is broad enough to warranty a separate topic on it's own but the first thing you might try is to get any reasonable OBD reader on the car and see if it reports a more specific (like a P-something) code. Then you can try and correlate that code to a Volvo code via another thread like http://forums.swedespeed.com/showthread ... rsion-List (not my link, just passing on, may not be 100% accurate but close enough).
To read the Volvo code you need a DICE and VIDA (can look "VIDA/DICE" up if you want, lot of info for what it does) although I am aware of other more advanced OBD readers that can display these as well.
Good luck!
Good luck!
- Been thanked: 4068 times
As you can tell from my sig, ECU problems are rarer than henways teeth.
Most ECM fault codes refer to a component fault detected by the ECU, Not an actual ECU problem
- 4413 Views
Last post by vtl
- 3880 Views
Last post by PixelDust
- 5260 Views
- 10 Replies
- 533 Views
Last post by lukask
- 2160 Views
Last post by maliszewskiigor
