Scared to loosen 18 year old thermostat bolts!
Did this job earlier in the year, but had the same concern about the bolts.98V70T5 wrote:I can't say my memory serves me well on the size. I have a full set of Torx bits, so it may be a T-40, I just typed the wrong size. Just for the record.
I PB blasted the bolts everyday for about a week.
Bought the correct size Torx bit from Home Depot (Husky?) Had no problem getting the bolts loose after giving them a few taps.
-Os
1996 850 GLT 262k miles (gone
1999 Honda Civic (gone)
1996 850 GLT (gone, no more Volvos
2000 Buick Park Avenue (gone)
2005 Honda Odyssey (gone)
2013 Lexus ES350 (replaced Volvo 850)
2021 Honda Pilot
2021 Honda Pilot
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
My soln was to buy a long-shaft Torx screwdriver with a flat on the handle. Even then I bent the male driver end! Used AL anti-sieze upon reinstallation. No worries since.
M1 10W-30 HM
M1 10W-30 HM
98V70T5
- Year and Model: V70 T5 1998
How did you get leverage using a screwdriver?sleddriver wrote:My soln was to buy a long-shaft Torx screwdriver with a flat on the handle. Even then I bent the male driver end! Used AL anti-sieze upon reinstallation. No worries since.
- Been thanked: 4071 times
Clean out the bolt head with a dental pick - really dig all the stuff out.
PB blaster or your favorite brew applied every day for a week before, then put the bit into the head and give it light taps with a hammer to work the solvent into the the heads
Go out and buy a brand new Torx bit, a good quality one (not HF) and even think about ordering a SnapOn if a stripped head will be a real problem.
Get the bit absolutely straight in and up/down before applying torque.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
+1 for Liberal and Long Term application of PB Blaster and getcha one of these:
Don't cheap out at Harbor Freight... Get a GOOD one!
- Has thanked: 311 times
- Been thanked: 817 times
With palm-heel of left hand, push the screwdriver straight down. Hard.98V70T5 wrote:How did you get leverage using a screwdriver?sleddriver wrote:My soln was to buy a long-shaft Torx screwdriver with a flat on the handle. Even then I bent the male driver end! Used AL anti-sieze upon reinstallation. No worries since.
With right hand, use channel locks on the handle to rotate the screwdriver.
My "long torx" for this application is actually a T40 screwdriver, that's exactly how I do it when a new (old) P80 comes into the fleet. Pliers will mar the screwdriver handle a little but that's OK. Second time around they are easy to turn, I just use the screwdriver by had. If I haven't swapped in cam cover bolts already.
98V70T5
Wow, that's a way of loosening them (screwdriver+channel locks), that I would have never considered. Is there an advantage in using the screwdriver vs. just using a ratchet and Torx bit?
- Been thanked: 504 times
When dealing with stubborn bolt, there are 2 different problems:
1. Broken in half: since the tstat bolt has a Torx head (and not a hex head), this is not going to happen b/c the Torx head will strip first as it does not have good bite like a normal hex head.
2. Stripped head, no worry, just drill it out.
Lowes Hardware sells good drill bits made by Bosch (made in Germany).
Robert DIY posted this video a while back:
Get 2 spare bolts ahead of time either from dealer or local hardware store.
Home Depot has these bolts: 7mmx1.0mmx30mm.
During installation, apply some anti-seize.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Please don't hit it with force. Changing the housing is no fun.
- 1483 Views
Last post by lummert
- 17 Replies
- 4733 Views
Last post by amblerman
- 1495 Views
Last post by skippy764b
- 2466 Views
Last post by jvl
- 2853 Views
Last post by thebull
