Changed c70 suspension for s70 suspension now wheels rub against inner guard
tashiiho
Year and Model: s70 1997
Post by tashiiho »
Hi I have a 1998 c70. When I bought it a few years ago it had been lowered and it was too low so I had a mechabic change the suspension from an s70 to it. I have the s70 because it went through a flood and was completely covered with muddy water.The c70 now drives smoothly and it steers perfectly, but the tyres rub against the inner guard and the cross member is on a slope. Does any kind soul know if the suspension is the same ot have I made a mistake doing what I di? Thank you for any advice.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
C70s usually have 4 bolt control arms. You can't have swapped the ENTIRE suspension from an S70 to the C70.
The front struts are the same and so are the tie rods and shocks if both were the same thread type. Was an alignment done to provide correct toe-in to manufacturer's specs?
Did the springs get swapped over from the C70? If not the ride height will be incorrect. Tyres rubbing could be worn or broken steering stops which are on each side of the front of the control arms. They are usually riveted on and could have come adrift causing the rubbing.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
What is dimension of tyres on c70?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
I would venture to guess you have the Canisto rims from the C70 on your vehicle with P225/45R17. If so, they will be too wide. I put a set on my 98 S70 T5 and both front and back rubbed. The original tires on the S70 were P205/50R16 and then Volvo transitioned to a P205/55R16. I would recommend a P215/50R17. I haven't had the cash to put new tires on the Canisto rims, so please do research before dropping $450 on a set of tires. If the tires are in good shape, spacers could be an option. I know IPD sells them Good luck.
jimmy57
Been thanked: 322 times
Post by jimmy57 »
C70 cloth top cars have a spacer where the spindle bolts up to the suspension arm. The track width is wider in rear as a result. If you dismantle the c70 rear and move the longer spindle bolts and spacers over to the s70 pieces it should push the wheels out and fix it.
Jedwar11
Year and Model: 2004 C70
Post by Jedwar11 »
I have a total Newbe question and I appologize if this is the wrong thread for this. I recently picked up 2004 C70 Convertible "on the cheap". I noticed the top of the strut mount in the engine compartment has a gap between the top rubber and the mount. I can clearly see almost a half inch of the shaft. Could the pervious fool of an owner have overtightened the retaining nut (Cross Nut) to lower the front suspension?
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Jedwar11 wrote: 29 Apr 2019, 08:37 I noticed the top of the strut mount in the engine compartment has a gap between the top rubber and the mount.
The strut mounts are worn out.
Take it to a mechanic and have him change out the strut mounts. I don't advise DIY strut mount replacement to anybody that does not know what they are doing. People have been killed when they lost control of the spring on the strut. A flying spring has the energy of a Cannon Ball. If it hits you, it can kill you.
Active
Past
Jedwar11
Post by Jedwar11 »
Thanks I was leaning that way. No cannon balls for me!!!
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
RickHaleParker wrote: 29 Apr 2019, 11:17
Go to Autozone and rent this bad boy. No chance of any springs jumping away and it is so fast and easy. Had a pair of those spring compressors from HF, they just turn into spaghetti noodles when you start tightening them.
BMW 540i 2002
S70 Base 2000
Has thanked: 311 times
Been thanked: 817 times
Brilliant! I never thought of using a humming bird feeder!!!
