T-IV is even thinner than Mobil.
Genuine Volvo ATF is NOT Mobil 3309...
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
I have trouble with that test. There may or may not be differences between these various 3309 spec fluids. But I refuse to form a conclusion on that. The fluid depth isn't the same between the little condiment cups (among other concerns).
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
About a week since replaced the fluid. All gears except 3 are unnoticeable, cold or hot. 3 (mostly 2-3, sometimes 3-4) is erratic, it can shift smoothly one time and give a slight jolt another. I'll remove B4 servo cap and inspect what's inside. Pretty sure this behaviour is caused by B4 band/anchor/cover.
All the rest of transmission imperfections was totally cured by Volvo ATF. Plus the car pulls as equipped with a rocket booster
vtl
Ok, I've solved my 3 gear imperfection. I had a wastegate actuator shortened by 1 turn. Bought a tool from ARD, returned pressure back to stock 1.8 PSI. After 3 engine starts and maybe 20 miles transmission is fully cured, I drive a 12 years old car with 157k miles on the clock and a perfectly working original transmission.
- Has thanked: 1505 times
- Been thanked: 3817 times
Interesting Vtl. I know jim has warned people not to play with wastegate adjustment on late P80 and P2 cars, sounds like that's good advice
vtl
I had to back out 2.5 full turns to return to stock pressure sensitivity, while I did 1 turn only few years ago. Looks like wastegate gets tired over years and needs to be calibrated once in a while even if wastegate actuator was never touched.
Is that lengthening or shortening the rod?
- mrbrian200
I need to do that too. However...vtl wrote:I had to back out 2.5 full turns to return to stock pressure sensitivity, while I did 1 turn only few years ago. Looks like wastegate gets tired over years and needs to be calibrated once in a while even if wastegate actuator was never touched.
I've been paying super close attention to mine I might also suggest the CBV operation starts becoming inconsistent with air temperature/heat soak conditions etc as they age. Some of this adjustment may be compensating for altered CBV properties. As with the wastegate actuator, operation is a combination of both spring/air pressure and the physical properties of the diaphragm itself.
