1997 850 NA - Switched to Pennzoil 5W-40
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Re: 1997 850 NA - Switched to Pennzoil 5W-40
Post by Sommerfeldt »
polskamafia mjl wrote:I would very much like to see a source for this.
+1
-S
[Sold] '97 S70 T5
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
xHeart wrote:It is now more than 40,000 miles since the PCV (5+ yrs), and regular oil and and filter change every 4-months. It has been running very well - no motor issues.
But, It burns a quart every 3000 miles in urban driving.
Several posts at MVS suggest 5W40 could be a better choice. I am upgrading from conventional Pennzoil 5W30 to All Synthetic Pennzoil Euro 5W-40.
So my goal is to 1) sustain PCV; 2) oil change once a year, and not have to add an extra quart between the oil change.
Any thoughts?
Update:
Poured in the last 1L bottle Euro 5W30 -- 12th bottle since switching March 2016. Used 6L+ at the time of switch, and then 5L+ since to replace burned oil.
Engine is running great, no issues with cold weather/ smooth cold start after overnight. Engine use to shake before turning over on conventional Pennzoil 5W30.
Extreme temps are coming.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
xHeart wrote: Update:
When switching to synthetic, I would replace the filter only after about 500 miles and look at it closely. If it looks pretty clogged, I'd do another filter change after 1000 miles. My engine did indeed drink quite a bit of oil when switched to synthetic for the first 5000 miles. Since then the oil level has been stable.
xHeart
Post by xHeart »
Oil filter? How will you stop 6L of fluid running out at 500 miles check up?
oragex
Post by oragex »
There is some oil inside the filter housing and it will spill, but most oil sits at the bottom of the oil pan. At least, that's on P2 cars, might be different on P1 models.
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
There is no need for that.It will not clog up.
Just perform a regular oil change....mineral old oil out-new full synth oil in.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
I'm no oil expert, but if you're oil filter is "clogged" after 500 miles, you probably want to start saving for a new engine. :lol:
2000 V70XC - 340,000 miles
2023 V60 T8 PE
Has thanked: 1505 times
Been thanked: 3818 times
You can tell if it's clogged by looking at it, anymore than you tell how dirty oil is by looking for it.
xHeart
Post by xHeart »
LoL!
Colder morning.
Cranks, starts, but engine won't stay running after a second or two.
Searching MVS for topics on fuel related issues.
One or two second run/stall is classic immobilizer behavior - maybe the antenna ring is bad or dirty contacts?
The other thing easy to test is bad fuel pump relay - they often act up on change in temperature. The jumper wire is the definitive test.
