Removed the relay, tapped the red casing generously.
Installed it is back together, started!
Is the relay on last leg --- I don not have a record of it being replaced in past 9+ years?
Replace --$47 at local Volvo?
99 S70 won't start...fuel issues? Fuel pump relay Topic is solved
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
- Has thanked: 2200 times
If you have a PnP nearby I'd pull a couple of spares, test them in your car and keep one in the glove box with a Torx tool to remove cover should it fail again.
Ah, I got confused because you rode in on Charles' thread
Ignore My comment on the fuel pump.
- Been thanked: 504 times
I made a jumper wire as in the photo above.
It has spade terminals and inline fuse (IIRC it is a 15A fuse, blue color).
I always keep this jumper wire (together with Torx keys) in the glove box.
This jumper wire is more fool-proof (never fails!) than a spare used relay (you simply don't know when the relay goes south).
xHeart
All good!
Thank you for MVS -- fabulous DIY resource.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
+abscate wrote:It could be the pump is on its way out and it is working part time.
But...you can check for good 12V (that means battery voltage) back at the fuel pump to see if its a voltage supply problem first.
Just had a fuel pump do this to me over summer, would go for hours then make a quick stop and no restart for hours
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- shiloh51933
After replacing my fuel pump during the summer with a new assembly it died already. From day 1 it was very loud, you could hear it running all the time. Luckily I purchased it from FCP and they took care of the issue. It was a Proparts Sweden FP assembly and FCP actually is getting rid of that particular part from there site. Anyway I got the real McCoy, Genuine Volvo FP assembly.
Particularly on an AWD I know they are really expensive, but OE for me is he way to go unless you are wanting to cut hole in your floor. The huge amount of work involved it makes sense. Good luck 2nd time around!
Neil
Neil
- shiloh51933
Yeah i wasn't happy about it after I finished install first time, I couldn't believe how loud it was. I knew it was faulty after testing it. I ran it until it died, I had the Volvo pump in it's blue box waiting at home already for the day the ProParts Sweden pump died. 6 months .scot850 wrote:Particularly on an AWD I know they are really expensive, but OE for me is he way to go unless you are wanting to cut hole in your floor. The huge amount of work involved it makes sense. Good luck 2nd time around!
Neil
We all live and learn!
Good luck!
Good luck!
- 5089 Views
Last post by wizechatmgr
- 14 Replies
- 4910 Views
Last post by wjhandy850
- 11 Replies
- 2722 Views
- 1973 Views
Last post by aeg
- 1084 Views
Last post by ToriWhite
