This was done on a 1989 740gl
Step 1 Disconnect Battery
Step 2 Remove connector from ECT
Step 3 Remove connector from Knock Sensor
Step 4 Grind small corner off 3/4 wrench
Step 5 Remove ECT sensor
Done
It took me longer to type this than it did to remove the sensor....
Remove the intake manifold?!
Um..a socket won't even fit over the plastic connector?
I had done research on this and thought it was going to be a cursing, tool throwing, bloody knuckled nightmare...
Seriously...less than 5 minutes. Cake.
Any questions, feel free to ask.
Super easy ECT removal 3 minutes
Jeff Schubert
- Year and Model: 1989 740gl
1989 Volvo 740gl
1956 Ford F-100 Big Window
2006 Honda Shadow Saber 1100
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
A deep well socket will fit over the plastic connector. A 3/4 inch or 19 mm deep socket, 4 inch long extension, and a 3/8 inch ratchet will fit under the intake manifold.
1988 Volvo 760 Turbo Wagon
Jeff Schubert
Maybe my plug is aftermarket but I couldn't get a socket to fit. The connector is in the way of the flats.
Nope, it says Volvo on it...?
1989 Volvo 740gl
Jeff Schubert
Sorry ignorant question. ...
This is at about room tempreture. Would this read as 2410 ohms?
If so that should be within spec?
1989 Volvo 740gl
lummert
That connector looks odd.Jeff Schubert wrote:Maybe my plug is aftermarket but I couldn't get a socket to fit. The connector is in the way of the flats.
Jeff Schubert
The other says SWF Germany 601 607
The plastic plug part is wider than 3/4, maybe 13/16ths.
I just had it in the freezer for about 30 minutes and it seemed to level out at what I believe is 14100 Ohms.
I don't think there is anything wrong with this sensor. I have yet to test 'boil' it, but room temperature around 3950 ohms and 'frozen' around 14000 ohms, don't think its necessary.
Next test...blah still chasing problems...
1989 Volvo 740gl
lummert
Could the connector be slightly rotated? the first time I replaced the sensor on my 1988 760 Turbo the connector was coming loose due to corrosion.
Jeff Schubert
No, seems quite solid. Im no body builder but it seems it would take a lot of effort to turn it or break it.
1989 Volvo 740gl
- 4118 Views
Last post by oragex
- 1113 Views
Last post by voom8
- 1538 Views
Last post by martynj
- 5020 Views
Last post by rollin_home
- 10 Replies
- 2321 Views
Last post by draser
