I had an oil change at the end of June and they put synthetic and said I should be good for 7,500 miles. The engine had about 203,500 at the time. Just brought it back to get checked out cause the engine was occasionally sputtering at start up, but it is hit or miss. They couldn't find anything, but said I needed an oil change as it was dark and is over 2 quarts low, but did not mention anything wrong with the engine. It was actually 3 quarts low! Should I bring it back or is this normal?
Thank you.
96 850R Losing Oil
- misha
- Has thanked: 155 times
- Been thanked: 432 times
3 QUARTS LOW???
Top it up to the middle of the dipstick....if damage isn't allready done and hope for the best.
I would never understand WHY is it so hard for people to check oil level at least monthly?
What oil viscosity is in the engine?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Was the oil light on?
- Clemens
- Has thanked: 501 times
- Been thanked: 228 times
My wife was driving her NA 4 quarts low before i heard the rods knock. The light never came on though. Btw., the NA survived, these fortunately have tough bottom ends as someone told me back then.
Also, switching to synth increases oil consumption on alot of high mileage vehicles
Check regularily!
Check regularily!
1996 855 R,
2010 V70 D5,
2010 V70 D5,
tryingbe
- Year and Model: None
- Been thanked: 26 times
Use whatever type of oil (synthetic/conventional/blend) you want, but keep the oil level checked and full.wackenhut wrote:Is it true that once you change to synthetic, you can't go back to a synthetic blend?
You will have no one but yourself to blame if you run it out of oil and seize the engine.
Your engine probably needs a PCV service and a have its valve stem seals changed.
https://www.matthewsvolvosite.com/forums ... hp?t=57864
https://www.matthewsvolvosite.com/forums ... hp?t=76949
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
In Florida, you should be running 10w-40.
- 1699 Views
Last post by Rbaratt
- 2211 Views
Last post by Sommerfeldt
- 1598 Views
Last post by cuhfs
- 13 Replies
- 3328 Views
Last post by 93Regina
- 13 Replies
- 2252 Views
Last post by BEJinFbk
