Thanks guys. I think I will replace it anyway. My son uses the car now and I know if I leave it it will fail when I have no time to fix it! Thanks for all the suggestions and inputs.
06 Xc70 cabin blower motor options Topic is solved
- Has thanked: 2199 times
If you use leftover CV joint grease you can enjoy the smell of MoS2 in the cabin permanently but you will save at least 2 cents, Canadian.beigg wrote:smear trans assembly lube on the bearing, it bought be 2 years before i replaced it.
lol, minds well go the extra mile and use rearend dope. mmmmmm the smell of rancid feline urine being heated up..abscate wrote:If you use leftover CV joint grease you can enjoy the smell of MoS2 in the cabin permanently but you will save at least 2 cents, Canadian.beigg wrote:smear trans assembly lube on the bearing, it bought be 2 years before i replaced it.
Trans assembly lube is very low odor and is safe for select bimetal use.
ugh smh 850 Turbo fridge
