I have 3 that will eventually go to scrap out there at the moment and yes, my wife says it looks like a junkyard. When the R wagon she was driving split an oil cooler and filled the cooling system with oil, overheating it, she did not complain about me having a Platinum sedan I bought 6 months ago with a bad trans ready to go the next day. I used to do this with GTOs (had 13 at once) but they are getting too hard to find too valuable to use for DDs.erikv11 wrote:Especially if you are doing upkeep on several P80 cars, having a parts car saves you tons of time and money as compared to going the junkyard. Once you actually try it, you will understand. Easier, faster, cheaper. The drawback for me is deciding how long I want to have a shell of a car hanging around out in the back driveway. If I had some kind of large garage or outbuilding, I would probably have a parts car at all times.
1996 850 rough running, bad FI 2, bad ECU....That rare occasion when it IS the computer
- greg850r
- Year and Model: a long list
- Has thanked: 5 times
- Been thanked: 26 times
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- Has thanked: 311 times
- Been thanked: 818 times
13 GTOs at once ... I am not worthy.greg850r wrote: ... I am living the good life ...
- greg850r
Let it sit overnight with the battery disconnected and then put a jumper between the pos and neg cables to be sure. Plugged into OBD and powered it up with key in position II. I thought my fuel trim would now be zero as there has been no run time. Oh, and the DTC is 1310
Follow up: Found a missing cap on the vacuum tree that was sucking air and fixed it. Took the car for a drive with scanner on live data and witnessed huge negative short term fuel trim numbers in the -20s.
- DTC.jpg (48.6 KiB) Viewed 785 times
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
99 C70 Convertible
96 850R wagon
96 850T wagon
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
- 36 Replies
- 4156 Views
Last post by PeteB
- 11 Replies
- 3296 Views
Last post by precopster
- 22 Replies
- 1987 Views
- 674 Views
- 22 Replies
- 5920 Views
Last post by dobrosailor
