Hi guys,
Hear me out if you will; 96 platinum 850 wagon with193k. Just rebuilt the head a few months back, engine has been running great; no codes, but turbo barely boosts into the white, perhaps an 1/8" when I'm pushing it on the turnpike. I replaced all of the old dry rotted vacuum lines, and any line that was showing age. Checked all hoses and intercooler lines. Thought it might be a bad TCV and swapped that out with a flea-bay TCV (perhaps it's bad as well?). No difference. I pulled the hose off of the wastegate actuator and tested that the turbo was in fact boosting (it did). I checked the diaphragm on the turbo when I had the engine apart and it was solid, no tears. So, there you have it. Any ideas?
Yet another low-boost problem post...
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
You have a small hole somewhere, or a pending code in the system. When my car dropped a pending P0420 code, (no cel), it would not boost. One open vacuum port hole can cost you 6 psi. Also, get a real boost gauge to test your boost.
- Been thanked: 4068 times
TCV probably should be bought new, as it's a part which ages to fail, as opposed to digitally good/bad like a purge valve.
Of course, if you have a friend with a turbo you can test it out, go fir the PnP
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
I have a similar issue, and have the CEL on. Will pull codes this afternoon. Will start with vacuum lines. Good luck wih your low boost. Mine only goes up about 3/4 of max on the internal gauge.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
- rspi
Contact rspi..
That is where it should be, 3/4 into white.
- Jazzer
- Year and Model: 1996 850 Turbo
- Has thanked: 2 times
Mine used to go about 1/2 way into the white, and even that was a nice boost compared to now
Is there a way to test the TCV with a meter perhaps? It seems like that would be the quick fix, anyway.
- Jazzer
I'm also thinking it may be the line that I can't see, the one that goes back to the gas tank and runs along the fuel lines. I'll see if I can locate a link on here that will help, I seem to remember seeing it...
The DC resistance spec is 29.7 Ohms with no tolerance given. Ive measure this +- 3 Ohms on a small number of units that were working as well as a brand new unit.Jazzer wrote:Mine used to go about 1/2 way into the white, and even that was a nice boost compared to now
The valve is not operated in DC mode, though - it is driven by an AC signal of something like 70 Hz IIRC. You could get a rough idea on the duty cycle if you can hold load steady by watching the voltage on the pins as a fraction of the TCV, but this isnt going to be very accurate.
Like most things ECU, the TCV gets a constant 12 VDC and is fired by ECU grounding the other side of the solenoid, so be careful what voltages you are applying where when testing.
Ahhh...from jimmy57
The TCV is a winding of wire that when energized produces a magnetic force to pull the pin with sealed tip off its seat on one port and closes the other end on another port. When the relay closes the TCV has battery voltage or alternator charge output voltage on that pin and when not grounded on the other pin that pin also has the same voltage. When ECM grounds that pin it will for a few thousandths of a second have nearly 0 volts and then a for a few thousandths of a second it will be batt voltage again.
Duty cycle is how pulsed fixed frequency signals are measured. The TCV is cycled between non-energized to energized postions 70 times per second if I remember the figure. On each of those operating cycles the grounding percentage can change. Higher percentage of the time grounded leaks more manifold pressure back to the hose going to MAF-to-turbo hose and reduces the pressure going to wastegate actuator. This gives higher boost. If the boost is desired to be reduced by ECM then it reduces the percentage of the time the TCV is grounded (reduced duty cycle low) and the valve stays in the position letting manifold pressure (turbo outlet pressure on the 5 cylinder engines technically) be sealed in to raise wastegate actuator pressure therefore opening wastegate and reducing boost.
A voltmeter is slow to read and the average voltage will be shown on Vmeter when change in voltage is fast.. If the batt voltage is 12.0 and the duty cycle is 50% then the meter reads 6 volts. If the duty low is 75% then the meter would show 3 volts. This assumes the ECM transistor is able to give a no loss, 0 V signal. Realistically it is likely .7V when grounded so maybe 6.35 V @ 50% and 3.17V @ 75%.
Duty low is ground or low volt % of time and duty high would be the remainder of the time when signal is at high level. Duty low and duty high always equal 100% when added.
- 1151 Views
Last post by lummert
- 3490 Views
Last post by polskamafia mjl
- 14 Replies
- 10077 Views
Last post by Alp
- 506 Views
- 689 Views
Last post by JRL
