2004 XC ABS & Check Engine Light On, Speedometer not Working
jb1882
Year and Model: xc wagon 2004
Post by jb1882 »
A few days ago started getting some messages ... ABS & Check Engine Light On, Speedometer and tachometer not working. When I press messages button, states transmission needs service.
At first I thought it was just because it was cold. Turned off and back on ... lights disappeared. It is continuing to happen. Sometimes it helps to turn car off and back on.
Something thing similar happened to another Volvo. With that one I pulled the ABS module and had it rebuilt and it was fine. I dont recall the transmission message with that car though.
Will be bringing in to be looked at soon but am wondering if anyone has ideas as to what it could be. Is the car safe to drive or will it eventually stop running?
Thanks
Been thanked: 4065 times
If you want to work on this you will need to get the specific codes read from the OBD port. This will guide you to the issue.
The transmissions on these cars are solid and last a long time if you respond to maintenance promptly
jb1882
Post by jb1882 »
Thanks. It is going to go in on Wed.
I read through the forums looking for others who experienced. One person suggested beeping the horn. I did this and all the messages disappeared and speedometer and tachometer working. Thoughts on this?
Lol.
Maybe thumping the wheel jiggled the ignition switch
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Watch this (till the end), the car is actually a 2004 like yours, not a 2003
Just don't walk into the Volvo dealer. This is typical issue with which the main dealers will make it a pleasure to do a costly repair (over $1000) without even fixing the main issue. Check instead the Xemodex site.
