A/C belt too tight? High Pitched squel
kevins s70
- Year and Model: 2007 XC70
I have a V50 that I just bought and just finished doing the timing belt. I replaced the alternator belt and the A/C belt in the process. To get the A/C belt on I needed to push the tensioner right back and it was still difficult to get the new belt on. I compared the new belt to the old belt and they are almost the same length. After releasing the tensioner i find the belt really tight - is that normal? I checked the tensioner on the alternator and that seems a bit looser - more of what i would expect. I also hear a high pitched squeal or tone that i think is coming from the A/C pulley and being caused by the really tight belt - Is that normal? I think I did hear this same sound before i touched anything but am really suspect now. I would have thought the tensioner would weaken with age so this doesn't make sense. Has anyone else observed this? The S40 from 2005 to 2009 appears to have the same tensioner system. Thanks in advance
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Yeah- which belt did you buy? What company's belt? It seems odd but bearings going bad in the tensioner could do that too...would seem odd it happens when you put a new belt on but these Volvo's have had more than their share of "coincidental" parts failing- all of them and I don't know why.
kevins s70
This is what I found. I still have the high pitched squeal but i really think that was there before i touched anything. I have noticed that the squeal only occurs when idling. In gear and moving the squeal goes away. As for the belt tightness issue here is what is found. I double checked the belt (Conti) and it was the right one. The size of it matched up exactly to the old belt i took off. Even the old one takes some effort to get on - it is tight by my standards. What is found is that the new belt goes on even tighter - this appears to be due to the distance between the ribs on the belt. On the new belt the ribs are tight and does not let the belt fully ride down on the pulleys. I suspect with time the belt would soften up but this appears to be the only difference between the belts. As i indicated even the old belt was tight by my standards to get it on.
MadeInJapan
Only in gear...hmmm Is yours a manual transmission or automatic?
- 11 Replies
- 4394 Views
Last post by beigg
- 443 Views
- 104 Views
- 2500 Views
Last post by Volvo Kush
- 815 Views
Last post by APCalifornia
