Looking for a new car, found a one owner 2004 V70 2.4 fwd with sunroof and automatic, car has 147k miles, body is in near perfect condition. Car has a P0192 ( fuel pressure sensor), alarm service required light on and driver seat leather has a hole on the side. As I read, these car seem pretty reliable, and not too bad on fuel. What kind of mpg should I expect, fuelly says around low 30, are these numbers realistic? What should I be aware of??
I am a 20+ years vw mechanic, and my wife have a xc90 V8, so I played a bit on her's.r Am hesitating between this and a jetta wagon tdi. I know the tdi might cost more in maintenance, but I have a hard time forgetting the 50+ mpg I used to get from a tdi.
2004 V70 2.4
britishrocco
- Year and Model: 2007 xc90 V8R
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Fps is very common and easy repair, look for Bosch, turbo and n/a have different numbers. Siren module can be disconnected or replaced. 150000 miles is a lot of miles for this car driven in Montreal. despite the looks it's surely quite a bit tired. I get 18 mpg in city 38 on highway.
- oragex
Yes 38 on highway, but this is the non turbo engine. The turbo gets lower mpg
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Uhhhhhh, OK. Personally I find the old fashion "miles travelled divided by gallons burned" to be a bit more telling. In our case it's about 20/27 for the turbo and 21/29 for the non-turbo. Of course the highway values are measured at around 75-82 mph.
- oragex
Indeed, 75 mph will make a difference. My value is at @ 65mph. As for the non turbo, there is a significant issue with the intake air thermostat, maybe you are already aware of it. When it fails, it really drops the mpg but only on highway by a good 5 mpg or more.
chrism
I wasn't aware on an inherent problem with the intake air thermostat (temp sensor?). Do you know there are any temp vs resistance specs available? I have a Haynes book but not at hand right now.
- oragex
Here's what it looks like. The part is not available at Volvo, unless buying the whole air box unit
The thermostat metal pin should open about 1/2" at room temp, and almost fully retract in freezing temps. Usually it gets stuck fully closed.
and a neat fix on older models https://www.matthewsvolvosite.com/forums ... =1&t=74712
chrism
I'm away from my 2003 V70 NA right now but will take a look at it when I get the opportunity. However the last time I had the intake duct off I don't recall seeing the flapper shut. I think I would have noticed and questioned it if it was closed. Thanks.
- 754 Views
Last post by Synergychaz
- 969 Views
Last post by Faust
- 2098 Views
Last post by cn90
- 1534 Views
- 3557 Views
Last post by 93SCMax
